  New Posts New Posts RSS Feed - Dual Band ADSB In Solution?
rolfe_tessem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Topic: Dual Band ADSB In Solution?
    Posted: 31 May 2019 at 11:17am
I'm asking one more time before I get rid of my AXP-340...
Is there any dual band ADSB-In solution on the horizon?
Rolfe
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 1:34pm
Following with interest.
CubedRoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CubedRoot Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 1:47pm
Following for the same reason...I'd like to know.
I have an AXP340 and a Skytrax 100.... I have been dissapointed with its performance, and single-bandedness.  It's sort of sad that my homebuilt Stratux picks up more traffic than the many thousand dollar AXP340 / Skytrax 100 combo.
bellanca1730a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bellanca1730a Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 9:59am
Sean Andrews
Bellanca Super Viking
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 10:00pm
You might have to squint to see it on the horizon.  I can't tell you our groundspeed, but it's not zero.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CubedRoot Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 10:13pm
Does this mean there might be some sort of upgrade love for us that bought an entire Avidyne stack, and are not happy with the Skytrax 100?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2019 at 10:17pm
That's a question for the sales team.  I'm just the engineering guy...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 3:14pm
Ideally, it should be something that:
Receives dual-band
Can be anonymous (has a UAT-only out mode)
Produces traffic audio alerts
Post Options Post Options   Thanks (0) Thanks(0)   Quote bellanca1730a Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 3:23pm
David - Not understanding why a dual-band IN solution would need an anonymous OUT mode, unless of course you’re thinking of an all-in-one solution to replace our AXP340s.
Sean Andrews
Post Options Post Options   Thanks (1) Thanks(1)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 9:15am
FYI, in response to an email inquiry, I received this from Freeflight Systems yesterday:
Good Afternoon Rolfe,
We are currently working on getting a dual band version of our RANGR Systems certified and expect to be in production of these units in October.  Would you need an internal WAAS/GPS within the box or not?  We will have both options available.  I have attached a specification sheet detailed all of our RANGR ADS-B In options including our dual band options that will soon be available.
Please let us know more about your aircraft and we would be happy to send you a quote.
Sincerely,
Clayton Maderia
Channel Sales Manager | FreeFlight Systems
1 (254) 230–3489 | cmaderia@freeflightsystems.com
8080 Tristar Suite 100 | Irving, TX
https://www.dropbox.com/s/9vyya5u6fr2am84/RANGR%20RX%20Spec%20Sheet.pdf?dl=0
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 2:44pm
Nice to hear of an actual date. I had just been getting a nebulous "we're working on it" before.
ronl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ronl Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2019 at 5:36pm
Good to know because my MLB100 doesn't see but about half the traffic that shows up on my active traffic system (Flightwatch).
Will it be fairly easy to replace the MLB100 with an FDL-978-RXD using the same antenna and wiring?
Ron L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2019 at 5:46pm
Sincerely,
Clayton Maderia
Will it interface with IFD 440 and MFD EX5000 to display weather and traffic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2019 at 2:37pm
Sincerely,
Clayton Maderia
Well, that is certainly the idea. But the question should really be posed to FreeFlight.
I am under the impression that these data exchange standards are open and non-proprietary, but I may be wrong.
Rolfe
