Visual approaches not available at ... |
Posted: 06 May 2023 at 9:36pm |
At airports without IFR approaches, there appears to be no way to select a visual approach. Ironically, that is the very type of airport at which you'd likely want to select a visual approach. Am I missing something? Sure, you can OBS on the airport as before, but not quite as good. Is it because the runways are not surveyed? * Orest
Edited by oskrypuch - 06 May 2023 at 10:01pm |
ricardo
Senior Member Joined: 17 Jan 2022 Location: Seattle, wa Status: Offline Points: 134 |
I think thats why.
Don’t have a link for the source . but i remember hearing in a some presentation that visual approaches require certain GPS data for the runway.
Edited by ricardo - 07 May 2023 at 12:42am |
LarryPetro
Groupie Joined: 03 Nov 2011 Location: Washington, DC Status: Offline Points: 66 |
Eagle Crest airport, DE25, doesn't have an instrument procedure, but AviOS 10.3 does present visual approaches to RWY 14 and RWY 32.
Edited by LarryPetro - 07 May 2023 at 12:45pm |
Melohn
Senior Member Joined: 11 Dec 2013 Location: PHNL Status: Offline Points: 129 |
INFO Airport Runways tab. If there is a Lat/Lon for each end of the runway, Visual approaches will be available.
Thanks. * Orest
