cross sync error on 540-440 |
Don
Groupie Joined: 21 Jan 2014 Location: Fort Worth Status: Offline Points: 58 |
Posted: 16 Jun 2016 at 10:34pm |
Just had my 440 installed and having a cross sync error
and the keyboard convenience is grayed and un-selectable the avionics shop was on the phone w tech support during install and said the data bases have to match did the data base update for both units but still the cross sync error is not going away any ideas ???
luchetto
I had the same problem. check the switches on the side of the boxes. one box needs to be set as the master. there is a description in the install manuals how the switches need to be set
Don
roger that ill take a look
do i need to pull the box out of the tray to get to the switch ? |
Senior Member Joined: 30 Dec 2011 Location: Kingston, NY Status: Online Points: 726 |
You will need to pull the units out of the rack to access the dip switches that control the IFD assignment number. They are located on the side of the unit. Having databases with different cycles will not affect the ability to cross sync. It will only affect the data that is synced. So for instance, flight plan info will not sync, but keyboard convenience will.
Don
Ok likely that is the case
i will check on that tonight thanks guys Will let you know the end result don
Don
The dip switch was the key. All working well now.
Thanks for the help. |
