  New Posts New Posts RSS Feed - IFD540 and G 796 (Aeras)
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: IFD540 and G 796 (Aeras)
    Posted: 12 Oct 2013 at 7:57pm
I understand that the IFD540s will not crossfill with the GNS530s, this is not the subject of this question.
The question is -- we have our GNS sending/updating its active flight plan to a dock-mounted Garmin 796. This is a simple serial input produced by the GNS, and input into the 796, using the "aviation in" format I believe.
This is a pretty common setup. Is this supported by the IFD540?
Edited by oskrypuch - 12 Oct 2013 at 8:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2013 at 5:59am
Yes, that interface is completely supported by the IFD540/440.   In fact, I use it every day in the Avidyne test airplane where I have some external devices on the glareshield that take data like flight plan routing in via the Aviation 232 protocol.
As part of the Plug and Play nature of the IFD series of products, we've tried to ensure that every device and protocol that the GNS units supported is also supported by the IFD.   HTAWS so far is the only known exception.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2013 at 11:29am
OK, good to hear, I thought I had read about the Aera type units somewhere but could not find that explicitly in the FAQ.
I expect that there is full compatibility with JPI 830 fuel flow & distance to destination type data back/forth on 232 as well, and ASPEN on 429 & 232.
Edited by oskrypuch - 13 Oct 2013 at 11:51am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2013 at 11:50am
Yup.
LarryPetro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2013 at 11:03am
And, Insight Avionics GEM G3 fuel flow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2013 at 3:34pm
Insight uses the same Shadin format on 232, so it should work as well. (not official answer)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2013 at 2:49pm
Well we're not explicitly calling out support for the Insight GEM G3 since it wasn't explicitly called out by the GNS530.   I haven't looked at the G3 Interface Control Document or equivalent so I'm not sure what data it's expecting to send or receive but as Orest notes, those standard 232 protocols are supported by the IFD540.
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2013 at 1:26am
Insight's G3 is working on my G 530.
BTW It was nice to see the 540 in action at AOPA's summit in Ft.Worth
Edited by Leonard - 21 Oct 2013 at 8:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2013 at 7:16am
In other words fuel flow from the G3 is showing up on the 530? If so, can you send me a copy of how your 232 Configuration is set up on the 530? I can provide instructions on how to find that if needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2013 at 9:01am
I've sent you several relevant Insight Avionics documents via private message.
-Larry
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2013 at 9:06am
As I understand, RS232, which the G3 and GNS 530W use, is an electrical standard.  I wonder whether the data formats supported by each instrument are compatible so that the system does work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2013 at 9:10am
That's good news.  If the IFD540 fully implements GNS 530W functions, then I would expect the fuel flow to display on the IFD540 too.  I hope Steve can verify that.
This page was generated in 0.191 seconds.
