Newbie to IFD440 - Best way to initiate approach? |
Author | |||
mvgossman
Newbie Joined: 16 Jun 2018 Location: KSTC Status: Offline Points: 35 |
Posted: 23 Jun 2018 at 12:01pm |
Totally new to the IFD440 and very impressed. A quick operational question.
Normally I would fly GPS direct airport to airport with the Garmin 430W since it's not always predictable what the approach will be. So I wait until the approach is given to me, or I receive what I ask for, and then activate the approach on the Garmin 430W and request clearance to turn to the IAF and if unable then await clearance to my preferred IAF or what they require for traffic etc. Sometimes however I fully expect what the approach will be so I will file Airport to IAF to Airport and navigate directly to the IAF to saye time. Seems there are three way to accomplish this when you know the approach you'll want or get, with the IFDxxx after filing Airport-IAF-Airport. 1. Create a flight plan Airport to IAF to Airport and select the approach without any resulting "Gap in route" and no need to Activate the approach. This idea came to me from an IFDxxx expert CFI. 2. Create a flight plan Airport to Airport, select the approach, and activate a direct to IAF right after takeoff. 3. Create a flight plan Airport to Airport, and file as such with ATC, waste a little time navigating direct along that course, select the approach when getting close, and Activate the approach. Am I understanding this new IFD way well? What's the best way? Mitch
Mooney M20J Aspen EFD1000 Pro IFD440
mfb
I think that you understand the process well. Any of those methods will work.
Method number 1 (file to the IAF) would create the least work for you and ATC. You just take off, go straight to the IAF, and shoot the approach. No muss, no fuss, no wasted clearances or time en-route. Just remember that anything can happen. Be prepared for a change in approach or runway when you get closer to your destination and know how to revise the plan in your IFD. Mike |
mvgossman
Thanks, I forgot to mentioned that option 2 is not recommended because you'd not be flying as filed.
squeege
Newbie Joined: 05 Mar 2013 Location: TX Status: Offline Points: 21 |
Mitch, Having completed the intense Gary Reeves CFII training last month, I integrated a few process changes. First, all planning is completed before ever leaving the ground. It is interesting reading your OP, as I used to do the same as you: prepare as best I could so I could accept the approach GIVEN to me, however, now I prepare all approaches, but as PIC I TELL ATC which approach I want (of course I still have all the approach plates ready for change of plans). This supports my Second (and agrees with Mike's approach): instead of flying to the airport, my route of flight is to the IAF/IF of the approach I want. In doing this, since it is already in your flight plan, you can avoid the "gap in route." One of the pearls that I have used that is not Avidyne based: I do not check in when flying on an IFR flight plan. I receive my clearance on the ground, take off before my void time and can now concentrate on flying the clearance, just listening for ATC to call me. When they ask "N1941M?", my response is N1941M [altitude]. It greatly reduces radio clutter. Louise
Catani
As for the OP, if your routes are short and the winds clearly favor a particular runway orientation, you can program your flight, including your selected approach, before takeoff without much concern for having to change anything. But for flights of several hours, winds can easily change. To simplify things, I do the same thing every time: the last leg of the flight plan is the last enroute fix on my flight plan, ending with direct from there to the airport. If I have a choice of enroute fixes, one of which is an IAF, I'll favor that. Otherwise, I'll wait until within range of ATIS, get the actual info on runways, and then add the approach to the IFD when I know what approach I want from those ATC would be willing to give me. You have plenty of time to do that if you make it a habit to get the ATIS when it first becomes audible. There's no need to overthink or overplan, and no need to commit to something that's hours away from takeoff.
+2, (on both) to Catani.
Edited by oskrypuch - 02 Jul 2018 at 9:24am |
squeege
[/QUOTE]The monkey is on your back, not ATC's, to report airborne and altitude climbing to.
[/QUOTE] I do not want to 7700 this thread; have the discussion with a Master CFII. Once you have your clearance, you are cleared into the system to fly your flight. You do not have to talk to anyone. Certainly have the frequencies pre-loaded and certainly listen for your call sign. It does not matter, as we all have NORDO procedures. Fly your clearance. Louise
Catani
Edited by Catani - 30 Jun 2018 at 3:55pm |
squeege
I'm sorry, I meant 7500, or hijack the thread. I do not discount your knowledge or experience. Of course I questioned this, then went and searched the FARs. It has been interesting and quite pleasant concentrating on piloting during my clearance time and entering the system. My transponder is sending off my discrete code. ATC can "see" me and speak to me when they deem it necessary. I am ready to respond with location and altitude, if they query. I base just outside of a Class B and the frequency is already congested. Good topic for discussion. Louise |
Catani
Yes, it's a good topic. IFR techniques and procedures are a deep source of aviation topics.
If you can't get a word in edgewise, you wait until you can, but you didn't limit your post to that special case. An extremely busy ATC Class B controller will fire off instructions like a non-stop machine gun, and one may be for you and hopefully you will be listening. Trying to butt in after another pilot's acknowledgement will often block the controller's instruction to the next guy. Fortunately, for the most part ATC's transmissions will punch through a block. You can't do what can't be done. Wait for a lull, and expect to be called before there is one.
However, waiting for ATC to call and ask if you are on the frequency after departure from the typical non-controlled airport is improper in my opinion, and not what ATC expects. Check with your Master CFI about his advice in that general condition.
Edited by Catani - 30 Jun 2018 at 5:56pm |
mfb
I am with Catani on this one. I don't really care what a master CFII thinks. I don't know how much time he's spent flying in the real IFR world.
I've flown in a lot of airspace, and I would never consider not calling ATC as soon as I could. Of course you need to fly the airplane first and comply with your clearance, but those should be pre-planned and second nature to you. It doesn't take much brain power to key the mike and check in on the frequency. Waiting for ATC to call you first will just keep everybody confused. Mike Edited by mfb - 30 Jun 2018 at 10:56pm |
Bob H
teeth6
Excellent discussion but I totally agree with Catani. I also asked a friend who is a controller in a busy Class C airspace who oversees many uncontrolled fields. She also agrees the pilot should check in as soon as practical.
This method may work well in your neighborhood (what part of TX do you fly in?), but I would caution you about expecting to use this method everywhere you go. I, too, base just outside a Class B (Houston) and sometimes the freq is congested, and sometimes it's not. Regardless, my release at uncontrolled fields typically includes the instruction to "Contact Departure on xxx.xx once airborne." Many of my clearances also include the instruction to fly an initial heading that's not part of my pre-planned route, so I'll need vectors from ATC to get established on my enroute course. Not calling them will only delay that transition. So in my part of the world, being able to use your method would be the exception, not the norm. In practice, if I'm departing an uncontrolled field, I'm making calls to take the runway and report my position as I depart the area, anyway. One more call to establish two-way contact with ATC is not a burden.
Edited by MysticCobra - 02 Jul 2018 at 9:53am |
paulr
Just in case we didn't pile on enough, +1 to Catani on this. I routinely depart an uncontrolled field that is snug up against the HSV Class C. It's not a terribly busy airspace but it gets far more than its share of military traffic due to our proximity to the USAF and USN training facilities at Columbus and Meridian, plus test/eval helo traffic from Redstone Arsenal *and* a frightening number of NORDO folks who like to putt along below the airspace shelf and look at trees or whatever without calling ATC. You bet your sweet bippy I'm going to contact departure ASAP so I have them looking out for me.
squeege
Please group: focus on the OP. The beauty of the Avidyne is the simplicity of programming. Look for the instructional videos (https://pilotsafetyorg.godaddysites.com/) here. Louise
Catani
Edited by Catani - 03 Jul 2018 at 3:42pm |
Edited by MysticCobra - 03 Jul 2018 at 10:33am |
Catani
