  New Posts New Posts RSS Feed - IFD 440 over heating
Plunger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plunger Quote  Post ReplyReply Direct Link To This Post Topic: IFD 440 over heating
    Posted: 26 Sep 2018 at 12:21pm
I have a new IFD440 and have a problem with it shutting down after being in the air for 1/2 half hour. I can get the unit to reboot after about 15 minutes but it will shut down in a few minutes. The avionics stack has a cooling fan. The unit gets pretty hot and I believe that that is the problem.
I can't get tech support to return my emails so it looks like I am on my own again. I have never had much luck with the Avidyne tech people. Has anyone else seen this problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 2:20pm
The primary method to reach tech support, is to call the toll free number. That has always worked for me. You will need to look at the logs, to see what is going on, to be sure what is shutting it down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2018 at 5:03pm
Can you not get service after the sale from your avionics shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plunger Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2018 at 4:32pm
My question was, has anyone had an overheating problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2018 at 8:57pm
The bezel gets hot, you'll see that a lot in the forums, but they don't overheat.  At least not as a design flaw, there have been reports here and there that usually end up with some installation issue.  We've been told that the bezel is designed to be a heat sink so it's supposed to get hot, mine certainly does, but I've never had mine overheat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Plunger Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 10:58am
My 440 will actually shut down and will not reboot until it has cooled down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catani Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:05pm
If so, you can plainly see that in the IFD's logs.  In which case, something is blocking the IFD's cooling air supply, or the cooling fan is inop (or is not yet installed).
It matters how hot it got before it shutdown.  Sometimes, letting it cool off and then turn it back on is the proper action.  But if the temp of the box got high enough, it's not airworthy and should be placarded inop and/or sent back for repairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2018 at 3:23pm
What you are seeing is definitely not normal, and certainly not usual.
You need to call Tech Support, and get the unit (or at least, first the logs) looked at. Let us know what they find out.
