  New Posts New Posts RSS Feed - IFD540 AND GTX345
IFD540 AND GTX345
jwalton49 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwalton49 Quote  Post ReplyReply Direct Link To This Post Topic: IFD540 AND GTX345
    Posted: 30 Oct 2018 at 3:15pm
Can someone tell me where Avidyne specifies the 429 data protocol between the GTX345 and the 540?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 8:02pm
The Avidyne Service letter 606-00182-015 of 3/29/2017
Edited by LANCE - 30 Oct 2018 at 8:03pm
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2018 at 8:03pm
not sure what you are looking for but the configuration settings are in the install manual.
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2018 at 5:52pm
How does this work if there is an EX5000 MFD in the setup? The 345 needs to talk to it using the same rs422 output port, but with a different format.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2018 at 5:31pm
can't do it. You need to choose.
matthewsjl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewsjl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 11:55am
Now I've been approved for posting, what is the purpose of the RS-232 line going from the GTX-345 pin 8 to the IFD pin 57?
John.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwalton49 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 12:00pm
Mine is wired like that but both ports are turned off so I guess nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewsjl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2019 at 12:08pm
Well, the line from the IFD to the 345 should be for GPS position source for ADS-B.
I too have turned off the 345->IFD and haven't noticed anything yet not working but it's also waiting to be flown after the install.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewsjl Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2019 at 10:23am
So, just to bring this full circle after speaking to Avidyne Tech Support.
For 10.2.3.1, the Installation manual has been updated to cover the GTX-345. Below is the wiring:
The settings are indicated as follows:
That should clean all this up.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewsjl Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 11:46pm
Question.....
If you don't have the AIRINC line between the GTX-345 and the IFD, does the RS-422 line carry wx and traffic from the GTX-345?
If using the setting "Capstone HS Wx+Trfc" would I get both wx and traffic on the display?
Is there any difference in the data stream between the AIRINC and RS-422?
John
PS: My reading seems to indicate that the GTX-345 RS-422 stream when set to "OPT LGCY ADSB" is the GDL-90 protocol...... but there is little information on this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote matthewsjl Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 10:36am
OK - so I tried to set "Capstone HS Wx+Traffic" as the receive protocol on the IFD and now have both displayed via the RS-232 line. No 429 line required.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 4:28pm
I get traffic over the ARINC 429 line from the GTX 345
In a one hour flight I get the TIS-B with the red circle and slash through it more than I get the traffic
It clears itself for a while but then fails again.
Anyone know why ?
forkauto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote forkauto Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 4:54pm
Could be that you are not picking up a station, If you are in the middle of nowhere, sometimes mine will go out or say degraded.
