  New Posts New Posts RSS Feed - ADSB in-Out transponder
Stevei View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevei Quote  Post ReplyReply Direct Link To This Post Topic: ADSB in-Out transponder
    Posted: 17 Mar 2019 at 3:47pm
I'm going to install one next month, the Garmin 345, and want to know where traffic and weather can/will be displayed.
I have an Avidyne 540 and use an Ipad running Foreflight.
I'd love a split screen on the the iPad or 540 that would show flight path on top and and traffic below.
Is that possible?
George P View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George P Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2019 at 4:46pm
I have a ifd540 with a Garmin 345.  Traffic shows up on the Foreflight moving map display as well as the 540 moving map.  If you have available switches on you audio panel, you can route the "Traffic" and "Terrain" alerts so they can be turned on and off.  The "Terrain" alert can be rather annoying if you are flying in mountanous country VFR intentionally close to terrain.
comancheguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote comancheguy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 10:02am
I am about to do the same thing:   Add a 345 to my two IFD-540s.  I have XM weather now.
1)  Can I send XM weather to one 540 and ADS-B to the other?  Or is it one or the other?
2)  Are the traffic and terrrain alerts seperate?   i.e. Do they both go to one audio input?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 1:43pm
Yes, you can send XM to one IFD and FIS-B to another.
Post Options Post Options   Thanks (0) Thanks(0)   Quote comancheguy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 2:11pm
Even with the data bus shared and all?
I might be better off with XM weather on the IFDs and traffic.  And use the ipad for the ADS-B weather.
Just trying to figure out how to tell the shop to wire it.
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 3:32pm
The IFD allows you to turn on the weather overlays, so you can always turn off what it displayed. I don't know if you can do that for traffic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stevei Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 11:41am
Foreflight can't do a split screen with traffic, at least not yet. Maybe someday.
I added the data block on the IFD 540 to show the traffic "circle" on the left side. Let's see how that works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote comancheguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 7:08pm
So, the airplane goes in Monday for the GTX-345 addition.
Again, I have two IFD-540s and XM weather and stormscope.
What should I ask for:
1) Where to route the weather?    Traffic?
2)  I want aduible traffic alerts on an audio panel button, so I can turn them OFF.
3)  Move OTher IFD alerts, (obstacles and terrain) to an unused audio panel button (same reason).
What else???
Who else has done this?
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote comancheguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:29am
Kudos to Christine at tech support for answering my questions!!!
She is the best (again)!
Ken
This page was generated in 0.123 seconds.
