  New Posts New Posts RSS Feed - Docs error
Docs error
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Docs error
    Posted: 19 Apr 2014 at 10:21pm
Pg 4-22
"Dest. Along Track Info"
... and estimated arrival time in HH:MM format ...
SHOULD READ:
... and estimated time enroute to the destination ...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2014 at 9:19am
Good catch, thanks.  Just corrected in draft 00-E that I expect to post later this week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2014 at 5:59pm
Another small PG correction …
on page 1-14, middle paragraph, "…and the Map tab on the MAP page" should read "… and the DATA tab on the MAP page", at least according to the screenshot below.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 3:44pm
No, technically that is not correct.
On the Map tab of the MAP page, the side tab will be present.  The side tab itself is labeled "DATA" to indicate what stuff you are pulling out for view or pushing back to hide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 5:19pm
Got it.
Jack Seubert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack Seubert Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2014 at 5:55pm
I am wondering if there might be a way to indicate the changes to the Pilot Handbook with the each of the new releases.  It could be a page which notes che changes or additions.  Another possibility might be a line along the side margin.  It would sure make it easier to see the updated information.
Jack Seubert
Jack Seubert
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2014 at 7:53am
There certainly will be with the official published one that comes out with TSO.  That's what that inside front cover will be all about.  It will indicate what pages have changes and those pages will also have change bars.
It's a little problematic for the pre-TSO versions that I keep posting.   I will however keep track of changes from here on out until TSO and publish a list of changes with each pre-TSO release.
This page was generated in 0.071 seconds.
