  New Posts New Posts RSS Feed - Tardy entry
Tardy entry
frankbell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankbell Quote  Post ReplyReply Direct Link To This Post Topic: Tardy entry
    Posted: 13 Jan 2024 at 9:30am
IFD 540. Trying to figure out what happened one evening at KHEF.  Had entered a FP, KHEF GVE KAVL, activated it, then entered the ARSENAL FIVE departure (at least that’s what i think I did).  The course lines would not show up on the screen.  Is there a scenario where the IFD gets confused if the departure is entered AFTER the route is activated?  What else might cause the route not to display after a FP is activated?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2024 at 9:41am
The IFD map generally displays legs from the prior to the active leg through the end of the flight plan.  If you entered origin KHEF, then GVE and KAVL, and then activated it, then the active leg would have been GVE.  If you then entered the departure on KHEF, those legs would have been inserted prior to the active leg.  That's why you didn't see the legs of the departure on the map.
