  New Posts New Posts RSS Feed - IFD 550 Fails to Boot Up
Toadpilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Topic: IFD 550 Fails to Boot Up
    Posted: 28 May 2024 at 10:21pm
Hello,
I have submitted a trouble ticket with Avidyne Support, but I wanted to see if anyone else has had this problem and what the remedy was. Sometimes, during powerup of my IFD 550, all I get are vertical lines on the display and it will not boot up. My only recourse is to pull the circuit breaker to secure power and attempt a new restart. Sometimes it boots up correctly after doing this, sometimes it takes several attempts. I am not having any luck uploading a picture, but I will try to get one uploaded to show what I am trying to describe.
Jeff Hullinger
1964 Piper PA-30 N97VP
IFD550/IFD440/EX500/AMX240/
RDR2100/GMX345/GDL69A/
SKY497/STEC60-2/G5 AI/G5 HSI
Mike_vonb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike_vonb Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2024 at 8:23pm
I had exactly the same problem recently where the 550 wouldn’t boot. It was out of warranty and cost a small fortune to ship from Australia to the US and have the aircraft out of service for 7 weeks. Apparently a bad internal CF card was the likely problem.
Wish there was a cost, and time, effective way of getting this stuff fixed. It’s the second big 550 challenge I’ve had in the last 18 months where the first resulted in a 3 month hole in the panel :-/
I guess outside the US you just don’t have anything like the same level of support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toadpilot Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2024 at 10:04am
To follow up. I downloaded my logs and sent them to Avidyne. Avidyne support believes that I have a loose video card connection. Therefore, I had to pull my IFD550, drive it to my Avionics shop, and have them send it in to Avidyne to inspect/repair/test. I will follow up after I receive it back, hopefully with the problem fixed.
Jeff Hullinger
