  New Posts New Posts RSS Feed - Deleting SID
Deleting SID
compasst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote compasst Quote  Post ReplyReply Direct Link To This Post Topic: Deleting SID
    Posted: 31 May 2015 at 6:59am
While creating an IFR practice flight using the simulator, I inadvertently selected a SID from 1G5. Not wanting this to be part of the route, I tried to delete it. I could not delete any elements of the SID nor the SID itself. I had to delete the entire flight plan and reenter it. Is this intentional?
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2015 at 9:24am
If you selected this SID from the FPL page on the departure airport, you would just highlight that field again and hit the CLR button.  This would be the same process to delete an approach which you would want to eliminate
This page was generated in 0.058 seconds.
