Vertical speed selection |
Post Reply ![]() |
jblodgett ![]() Groupie ![]() Joined: 24 Sep 2013 Status: Offline Points: 62 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Nov 2015 at 11:20am |
Forgive me if this has been covered before. I am just now getting familiar with 10.1.0.0 and I can't figure out how to set the desired vertical speed. It appears to default to 500 fpm. What menu do I go into to select a different desired vertical speed?
Thanks, Jim |
AUX | SETUP | Setup FMS
Right at the top. Extremely powerful feature, especially tied to the (auto) vertical constraints you can put in. * Orest Edited by oskrypuch - 26 Nov 2015 at 11:46am |
brou0040 ![]() Senior Member ![]() Joined: 13 Dec 2012 Location: KIYK Status: Offline Points: 720 |
If you are trying to get the VSR to descend to your destination, you have to make sure to add a vertical constraint to the destination, otherwise it assumes you want to maintain your current altitude.
Their is no "Setup FMS" under AUX | SETUP. Not right at the top or anywhere else. Is this a 10.1.1.0 feature that I do not have yet?
DH82FLYER ![]() Groupie ![]() Joined: 15 Dec 2012 Location: Queensland Status: Offline Points: 88 |
Press the LSK "Setup Map" and it will change to "Setup FMS". |
Yes, as noted, just push SETUP Map. Wherever in the onscreen menu items you see a selection with both a cyan and a white label, pushing that button (or touchscreening) will cycle through a number of options. Look up LINE SELECT keys in the manual, around page 1-4, depending on which revision you are looking at. * Orest Edited by oskrypuch - 01 Dec 2015 at 9:22am |
Post Reply ![]() |
