  New Posts New Posts RSS Feed - Touch screen data entry on the IFD Units
77Mooney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Topic: Touch screen data entry on the IFD Units
    Posted: 23 Nov 2016 at 2:55pm
When typing with the touch screen the visual entry box display is behind and under your hand so it is not possible to see if you make a mistake without moving your hand.... a bit of a pain but not even close to a deal breaker... I love my IFD 540 and would think that it would only be better if the display window were moved to a position above the touch screen keyboard.
Edited by 77Mooney - 23 Nov 2016 at 3:02pm
AzAv8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:51pm
Ditto.  That keeps surprising me, and it sort of renders the "best guess" function pointless.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:16pm
Why wouldn't you use the BT keyboard, anyway?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 9:40pm
I use the keyboard when i have a lot to enter, but if it is a single entry or two, i don't bother getting it out and setting it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 8:30am
I don't have lots of real estate in the Mooney ... nowhere to mount the BT keyboard so in a turbulent situation it would be difficult to use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 9:18am
I mounted it on a simple bent aluminum support, on my yoke.
80% of my interaction with the IFD is by keyboard, with 10.2 that will be over 90% I'm sure. It is much easier to use it in turbulence, because your palm is supported. The positive click of the chiclet keys is also much superior to interacting with a solid touch screen virtual keyboard.
I absolutely love it.
Edited by oskrypuch - 24 Nov 2016 at 9:22am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 10:01am
.   I just don't have the room
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2016 at 11:14am
I like your setup I Orest, but like 77Mooney, I have a tablet mounted to my yoke. I have a custom center console tha I have thought about mounting it to, but I'm waiting until after 10.2 so I can figure out how I'll use the ifd100 - I may want to mount a dedicated ifd100 tablet there instead. Unfortunately I'll probably have to wait even longer since I'm on android. With the ifd100 on the center console and my arm/wrist supported on the armrest, I think I wouldn't need the bt keyboard.
Edited by brou0040 - 24 Nov 2016 at 11:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 7:31am
Do you use the ashtray?  That seems like a prime location for mounting the keyboard, just below the throttle quadrant.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 8:11am
I do use the ashtray... when opened it has a pencil sharpener inside and the tray catches the shavings... I see your point on that location but it is a bit far away and the wrong angle for such a small keyboard however one could make a angled mount... I will have to give it some thought. If only they would release 10.2 then the iPad on the yoke will be perfect.
Edited by 77Mooney - 28 Nov 2016 at 8:16am
MarkZ View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MarkZ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 8:31am
What's a pencil? :-D
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2016 at 8:50am
I have lead in my fuel and on my paper...  :)
Post Options Post Options   Thanks (1) Thanks(1)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 7:02am
I would like to poke fun, but I can't.  In fact in my airplane I have redundant pencils.  I have the regular pencil, and I have a #2 pencil.
I have found that a sharpened pencil only stays sharp briefly, but a "dull" or rounded pencil holds its condition forever.  If you don't need razor-thin lines in your writing, an unsharpened pencil can be good for years.  Just shave back the wood and expose the graphite.  As you write, the graphite tip becomes rounded.  Then it stays that way for a long time, because there is a tendency to rotate the pencil while writing.
Also, the rounded tip is more robust and never breaks off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 7:26am
I rarely use the sharpener and as you said the dull pencil will last a long long time however I like to have it just in case ... and just why I don't know...lol.... I keep a few pencils and pens in my kneeboard and a few more in my flight bag.......should probably just let it go...
Post Options Post Options   Thanks (1) Thanks(1)   Quote MarkZ Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 7:36am
I've found that it is hard to copy a clearance on an iPad with a ballpoint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 7:41am
Actually, I have a ballpoint pen that is also a touch-screen stylus when you unclick the pen feature.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77Mooney Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 8:28am
I like my paper for all my writing not my iPad ..... just my preference..
Jack
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 10:01am
Jack
I'm as computer geekie as they come but, absolutely, pencil to paper for notes. I have a paper TOLD sheet and keep a cruise diary as well.
My tablet works pretty well with a stylus, although not as well nor as fast as a sharp pencil and paper, and a tablet is far more likely to fail.
I keep a mini sharpener and spare pencils in my flight bag, and I'm good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2016 at 8:16pm
Very much agree with the pencil and paper technique.  Every single frequency change is first put on paper before I enter in the radio and switch freqs.  In the event of a sudden electrical failure, I have the frequency written down and can quickly enter it into my handheld.
