  New Posts New Posts RSS Feed - Tango / RNAV / t-route airway programming
skitheo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Topic: Tango / RNAV / t-route airway programming
    Posted: 16 Jul 2017 at 5:23pm
OK, dumb question here:
If I want to fly the t-routes (tango airways, AKA RNAV routes) depicted on the enroute low charts, how do I GeoFill those? I find jet and victor airways (J & V), but no RNAV (Q & T, respectively for high & low).
Am I missing something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 5:59pm
Clarification:
Simulator: KLMT -> MUREX ->(T261 should be available, but isn't) I have to go to the airport to check.
A very small portion of T259 shows up in the sim, terminating at KSJC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 6:47pm
Is the database up to date?
It does work in the real IFD, just the same as Victor or Jet airways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 7:48pm
Can you update the database? I tried just now using my the files for my IFD540. It had an error loading the navdata and skipped the obstacle database.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 8:45pm
I don't think there is a way to update the PC simulator, only the iThingy one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2017 at 11:01pm
Bummer about the simulator.
I ran out to the hangar and confirmed that all of the T-routes are in the actual instrument database. Planned out KLMT -> KSBA almost entirely on T-routes. 500nm.
Thanks Orest!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 11:12am
T-route availability is also easy to confirm in the IFD100 from home:)
Darren
