  New Posts New Posts RSS Feed - Decoded VLOC Datablock Busted?
jimmyz80 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Topic: Decoded VLOC Datablock Busted?
    Posted: 31 Aug 2017 at 1:05am
Originally posted by LANCE LANCE wrote:
When it says "LIB" under the frequency does that mean it's identified the station?
I'm thinking that based on proximity it's just getting that from the database that this identifier corresponds with that frequency. I think the only indication that it's identified it properly is the VOR/RAD/DIS datablock.
That better not be the case, or I might as well lock my plane in the hangar and throw away the key.  The datablock couldn't properly ID a navaid even if I pointed to it out the window. :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 3:32pm
Originally posted by 94S 94S wrote:
It's my understanding that the ID shown in the frequency box is confirmation that the station has been positively identified by the box decoding the Morse, the same as if you'd listened to the Morse yourself.  That's one of the handy features of the box.
94S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 94S Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 9:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2017 at 7:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 11:57pm
Ah, the VOR/RAD/DIS datablock?
Yep, take a look at the photo I attached.  You can see the datablock freaking out, despite the frequency box saying it was ID'd.
bobcain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobcain Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 8:49am
10.2 really improved decoding. Are you updated?
yes. And it certainly did help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2017 at 12:12am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 11:54pm
Yep I'm on 10.2.  The frequency box seems to ID quickly, but as I mentioned the datablock seems to spasm with the data coming and going much more frequently than the morse code would be cycling through.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 9:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobcain Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 3:38pm
Only a data point, but mine (IFD440) seems to require a really clear and pure signal to decode well. I can decode with my ears long before the radio will.
I figured this might be a factor of the radio needing to be really, really sure of what it's hearing. But.... ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jimmyz80 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2017 at 12:58am
Lately I've been using the "Decoded VLOC IDENT" datablock to keep an eye on navaids that I'm using, and the behavior has been odd to say the least.  I can have a VOR tuned in, hear the morse code as clear as day, see the ID properly in the corner of the frequency box, but the datablock will will flicker between being populated with data and being totally blank.
I can't imagine it's actually deciding that it can/can't hear the morse code, since the data in the datablock will come and go multiple times within the timespan of one morse code broadcast from the VOR.  Please see the attached photo that shows the datablock blank, even though the frequency box has it correctly ID'd.
Any idea what's going on here?
Edited by jimmyz80 - 26 Aug 2017 at 12:58am
