Sirius XM music |
Stevei
Groupie Joined: 13 Dec 2018 Location: No. California Status: Offline Points: 64 |
Posted: 09 Jan 2019 at 5:31pm |
I want to get their service.
What device do you use to get their signal?
forkauto
Groupie Joined: 30 Apr 2018 Location: Maryland Status: Offline Points: 51 |
I have a Garmin 696 panel mounted which has a XM weather and Radio antenna. It it wired to my Avidyne 550 and audio panel as well for cross fill of flight plans and alerts.
Senior Member Joined: 30 Dec 2011 Location: Kingston, NY Status: Online Points: 722 |
I have a Garmin GDL 69/A connected to my IFD540 and AMX240 audio panel. Integration works great with a page on the AUX tab to switch channels, control volume, and mute. I also wired external toggle switches to change the channel, volume, and mute. Works very seamlessly.
edanford
I use a SXAR1 xm wx portable receiver Audio input is done through a small bluetooth receiver plugged into my Aux input on PMA450. Tuning is done through foreflight. Bonus is that I can take this xm radio anywhere there is a device ( Car / boombox etc ) that has an Aux input
Ed
210 Driver
Newbie Joined: 28 Jan 2014 Location: Alberta, CAN Status: Offline Points: 39 |
Did you ever have the WX working on your GDL69A? I’d like to try the WX to see if I like it on the IFD540, otherwise may as well get rid of it. I can see and click WX products on the IFD but they don’t show up on the screen...
I had music show up but never could get it to play, but I think I only paid for the WX to test it. Rob
I have music and weather from a GDL 69/A on my IFD540 and it works fine.
210 Driver
Did you have it running when you pulled the G530? I hadn’t bothered to activate mine prior to the new 540, so we think it needs a firmware update. My buddy has offered up his 530 to do the update, hopefully this week!
How do you find the WX options on the GDL69A and their display on the 540 vs WX on other displays? Trying to decide if I should drop the XM WX on my AERA, to have it on the 540.
On my installation, I originally had the MLB700 for weather until SiruisXM turned off the feed. I then purchased a used GDL69/A. So, I've never had it connected to a G product.
I think the MLB700 weather was slightly better than the GDL69/A, but that is a function of the feed, not the display. I've had weather on an Aera before, and have seen it in a number of different airplanes I've flown. Weather depiction on the IFDs is very clear, sharp, and the refresh rate seems to be better in the recent year with the upgrade to the back end processing from SiruisXM. I much prefer the GDL69/A audio because I can change channels and manage it from the IFD rather than the silly remote I could never remember how to use. |
teeth6
Definitely agree about the remote. The GDL 69 is way better. On the few times I remembered how to use the remote, I couldn’t see what was on the screen. :(
Stevei
An update. I reconnected an "old" 496 and just have XM music that comes through the panel.
No XM weather. I get that through the Garmin 345.
vuk3@me.com
Newbie Joined: 16 Dec 2013 Location: Me Status: Offline Points: 23 |
Here in Australia we tune into AM radio broadcast music on the ADF / NDB Old school style. XM MUSIC?.... what's that?
My god you guys in the US Have it good. Cheers Ax |
VH-UAR YMMB
210 Driver
I do that to but hard to listen in the mountains!
210 Driver
You get XM WX through the 345, or the free ADS-B WX?
