Direct To |
teeth6
Posted: 06 Jan 2020 at 6:23pm |
I noticed a behavior on the IFD which I’d like an explanation of. I see the same behavior on the simulator and there must be a logical explanation.
I was on a flight plan to SFZ and on vectors for the GPS 5 approach. The approach was activated and then I was told “approach clearance cancelled,” proceed direct FOSTY and hold as published. FOSTY is where the hold is on the missed approach and was listed in the plan so I highlighted FOSTY and hit direct to but instead of of FOSTY coming up to accept the airport SFZ came up. I thought maybe I highlighted the airport by mistake so I again selected FOSTY with the same result. I ended up just inserting a new waypoint FOSTY prior to where the approach began and hit direct to which worked, but I’m wondering why the IFD kept changing my selected waypoint in this scenario.
dmtidler
From page 1-36 & 1-37 of the latest IFD500 Series Pilot Guide: If a different waypoint is
desired, there are a number of ways in which the proper waypoint can be entered
in that Direct-To dialog box:
It appears what you experienced is the way it was designed. Operationally, it appears that if you have Auto Enable Missed - On in the current user settings, a direct-to any fixed point in the missed approach procedure may be accomplished after crossing the FAF. With Auto Enable Missed - Off in the current user settings, a direct-to any fixed point in the missed approach may be accomplished after selecting Enable Missed (which will be available at LSK 4 after crossing the FAF). Edited by dmtidler - 06 Jan 2020 at 8:06pm |
teeth6
Thanks. I figured it was behaving as designed and reading that explanation makes sense. I didn’t realize the the missed approach procedure had to be active to go direct to the waypoint.
Thanks Darren. Very useful response, especially the operational implication of Auto Enable Missed setting in this case!
dmtidler
Three more observations regarding direct-to missed approach waypoints:
Edited by dmtidler - 07 Jan 2020 at 11:39pm |
