  New Posts New Posts RSS Feed - 10.3 Waypoint CAS message
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Topic: 10.3 Waypoint CAS message
    Posted: 18 Oct 2022 at 8:52am
I haven't heard others with this issue, but as I approach a waypoint, I get the normal CAS message on both my 550 and 540.  After passing the waypoint, the message disappears on the 550 as it should but persists on the 540 indefinitely until I clear it.  Often, the CAS countdowns to the waypoint differ on the units by a few seconds and after passing the waypoint, the remaining CAS on the 540 still shows X secs to the fix which appears to be the difference in secs from the 550 to the 540
Edited by teeth6 - 18 Oct 2022 at 8:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2022 at 10:54am
It's interesting that there's a time difference between the units-- I would expect both of them to have identical times shown if they're both getting the same GPS position data, etc.
This page was generated in 0.091 seconds.
