  New Posts New Posts RSS Feed - IFD XP Trainer Issues
jwalton49 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwalton49 Quote  Post ReplyReply Direct Link To This Post Topic: IFD XP Trainer Issues
    Posted: 02 Jan 2023 at 12:55pm
I have been trying to characterize the issues with using the XP trainer flying ILS approaches in xPlane.
I believe this is related to the ILS issue that Ricardo documented here. here: http://avidynelive.com/workaround-for-ifd-xp-trainer-ap-bug_topic2444.html
This seems to only occur if you activate an ILS approach while in GPS mode. and then  switch the nav source to NAV.
I have identified that the trainer is sending erroneous CDI errors (number of dots off) to the instruments. Using a network analyzer I have discovered that the trainer is sending these two xrefs with the wrong values.
sim/cockpit/radios/nav1_hdef_dot
sim/cockpit/radios/nav1_vdef_dot
xPlane tries to correct them which causes the needles to fight as shown in the video linked here: https://drive.google.com/file/d/1PPTHkWlv2ilY0QhXWoUGoLz73dnVuXZy/view?usp=sharing
At the end of the video when the needles calm down it is because I killed the Avidyne app on the iPad.
If the approach is activated while nav source is selected to NAV this issue does not occur.
vancinad View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vancinad Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 2:31pm
What network analyzer are you using? I have been interested in doing some of this investigation myself but haven't found a suitable tool. (Where "suitable" includes "very inexpensive"!)
ricardo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ricardo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 3:30pm
i used WireShark
Post Options Post Options   Thanks (1) Thanks(1)   Quote jwalton49 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2023 at 8:37pm
https://www.wireshark.org/ for me as well.
