  New Posts New Posts RSS Feed - Surefly electronic ignition
Dallas90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dallas90 Quote  Post ReplyReply Direct Link To This Post Topic: Surefly electronic ignition
    Posted: 19 Apr 2023 at 10:23am
Has anyone here replaced a Mag with a Surefly? I'm coming up on mag rebuild and considering it for my Cirrus SR-20. Does it cause any interface problems with your MFD? I would have the option of replacing the left or right mag, replacing left being recommended by Surefly.
LarryPetro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2023 at 4:35pm
Two years ago I replaced the left mag with a Surefly electronic mag. No problems with the MFD (or, anything else) were caused. I have dual IFD440 and Entegra MFD and PFD.
Edited by LarryPetro - 29 Apr 2023 at 4:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dallas90 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 4:07pm
Did it require the tach2 signal converter? Also, did you have any improved performance or decreased fuel burn of any note?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2023 at 5:23pm
My Surefly did not require the tach2 signal converter, but I did need a Slick ignition harness.
My sense is that starts are easier (i.e., quicker and without drama) and that fuel flow has been reduced 0.5 - 1 gph at 65% max rated horsepower. I do not have data to support that impression, unfortunately.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dallas90 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 4:10pm
Thanks for the info. I keep getting mixed messages on the need for the Tach2 signal box. Surefly thinks I need it and Avidyne has yet to respond.
dmtidler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 4:23pm
I had to install the Tach2 signal box in my airplane so that the SureFly ignition would properly display on my Horizon Instruments P-1000 digital tachometer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dallas90 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 5:49pm
I have the Avidyne Entegra PFD and MFD so that’s the equipment I want to keep happy. I don’t want to buy an extra signal conditioner I don’t need. Should happen within the next 3 months.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LarryPetro Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 5:51pm
I also have the Avidyne EXP5000 PFD and EX5000 MFD.
This page was generated in 0.057 seconds.
