FPL not syncing |
Post Reply |
Author | |
djbewick
Newbie Joined: 17 Jun 2023 Location: UK Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 18 Jun 2023 at 11:01am |
I'm running an IFD100 (10.3.0.2) on an iPad Pro (16.5) and an IDF440 (10.3.1.2) using a PilotAware Network (UK Electronic Conspicuity device a bit like Status) with both iPad and IFD as clients. Frequency sync works fine, however, FPL doesn't mirror. As I have confirmed NavData and Obstacle databases are identical on both IFD100 and IFD440, I'm guessing the problem is that the current S/W version for the IFD100 is behind the latest AViOS update to 10.3.1.2, but I've seen comments on here that suggest that others have made this difference in S/W versions work. Does anyone have any thoughts on what else to check? I have had this working under the previous 10.3.0.2 AviOS.
ricardo
Senior Member Joined: 17 Jan 2022 Location: Seattle, wa Status: Online Points: 133 |
Post Options
Thanks(0)
the ipad IFD app is at 10.3.0.2 .. that’s what everyone is running.
did you try quitting the IFD100 app and restarting it?
Post Reply | |
Tweet
