New MLB100 978 MHz ADS-B In Receiver |
Post Reply | Page <1234 5> |
Got it.
I don't envy you what you are doing, particularly WRT the Feds.
I fly with them for what they expect to be their final flight test of this and the rest of 10.1.0.0 on Wed afternoon (tomorrow).
Excellent!
888dom
Newbie Joined: 25 Nov 2014 Location: United States Status: Offline Points: 15 |
Do you anticipate having the Wifi unlocked with version 10.1? If so, have you also been able to secure an agreement with a vendor (hopefully Foreflight) that will allow us to show the traffic on our iPads until you're able to demonstrate what the FAA requires to get it on the 540?
Gary T
In a different thread discussion AviSimpson said bluetooth activation would be enabled ( version 10.1)
first and wifi released in a later version.
Gary-T
Not exactly.
All the code required for Bluetooth and WiFi operations are in Release10.1.0.0. But, the FAA has added additional cert requirements on the STC side of that. So, until the extra STC work is done on that (post Rel 10.1.0.0 STC), we have set an internal bit in a manner that disables the Bluetooth and WiFi functionality. Once that extra STC work is done, a software utility will be released (at no $ charge) that you can squirt into the USB port that will take about 4 seconds. As for the WiFi apps, the vendors all still want to keep mum until you can actually download them from the app stores. So for now, we stay tight-lipped. |
888dom
I did read that post Gary, thank you. I'm a little bummed that Avidyne somehow 'missed' the part where the FAA required directional icons for ADS-B traffic display. It seems like there must be published guidance of the rules to work from somewhere - the 'G' company must have read that line. I understand leaving things out for the speed of certification and I give Avidyne credit that since the release of the 540 they have been working feverishly to improve it. The speed to market problem still haunts them though and will for years to come.
Are there any teasers about the wifi/bluetooth iPad connection that you guys can share? I see this as likely the best feature of the 540. I've resisted buying a Stratus for 3 years hoping for a certified solution and on-screen display. I suppose another few months won't hurt me either but it's very disappointing that I'll still be waiting on ADS-B traffic on my 540 if I do purchase an MLB 100.
To be clear, we did not miss that guidance. There is a clause that permits exactly what we did but an internal argument with the cert authority overroad and the subsequent course reversal came too late in this project.
Understandably, those who have bought these boxes want all the functionality and gee-whiz factor obtainable.
I think Avidyne is trying to deliver this as expeditiously as they can, given that they carry a 100-stone (FAA) weight on their back, and are probably limited in coding staff. It is in Avidyne's best interest competitively to bring innovation to the marketplace as quickly as possible, and it is pretty obvious to me that Avidyne is trying to deliver on that. It has been a long slog, though, in the Avionics marketplace in general with all the "coming soon..." announcements that has become the modus operandi for this market segment. I understand it - jockeying for market share must be the driver. Thanks, Steve.
SB Jim
Thanks, Jake. Sounds good to me. I am very interested in your product to make sure the integration works well. Plus I can let my bank account recuperate a bit. Separately, would there be any benefit to having this particular box be a dual band receiver? (1090 and 978) I suppose it could pick up some traffic when outside the ADS-B broadcast area. I have noticed that my current setup doesn't pick up targets until I'm up in the air a bit (above pattern altitude). Regards, Jim |
SB Jim
Hi Tom, I didn't give up my CNX 80 (aka GNS 480). It simply became GPS/Nav/Com #2 and my '76 vintage Collins Nav/Com, ADF and 90's vintage KN 64 DME were removed. I agree that the 540 is like a 480 on steroids, we are very pleased with it so far. |
Jim:
Just my opinion - I think the best solution is a traffic system like the TAS605A which will have 1090 in. Then all you need is 978 in to catch FIS-B and the TIS rebroadcast. If you don't have 1090 traffic then I think the dual frequency box is the best solution. Best. David
Agreed, that is what I did, but that is pricey. And actually, the TAS605A will pick up the TIS-R (978, 1090 & Mode C traffic) on 1090. You only need to add 978 if you don't have satellite weather and want FIS-B weather. * Orest |
SB Jim
Agreed, active traffic is the best, but I'd rather save that money.
Still, it won't catch them all either. Plenty of airplanes still flying without an electrical system or a transponder. Regards, Jim |
Yes, we have to hunt them down. ;-) The Pattern at small uncontrolled fields on a blue sky day can be scary. * Orest |
comancheguytoo
Newbie Joined: 17 Apr 2015 Location: CA Status: Offline Points: 29 |
Hi Jake, just received my 540 & 340 yesterday and am awaiting the MLB, but Az does raise one interesting point about supporting 978 only. Maybe you could clarify.
With 1090 out only(AXP340) and 978 in only(MLB100), it seems like Avidyne guys could be in a scenario where they can't see one another(less TAS of course), when guys with cheaper systems could see us and themselves. i.e. If two of us with 540/340/MLB are flying outside the UAT envelope(Owens Valley, CA for instance), we'd both be transmitting out 1090, and both waiting to hear on 978, and we might see the Cub below us with a Freeflight transponder, but we'd be running in stealth mode for each other. Does that sound right? |
n7ifr
I believe your AXP340 1090 OUT will trigger ground station FIS-R which will then send a signal on BOTH 1090 and 978. So, in fact the MLB100 Traffic IN on 978 will be seeing traffic from both sources, and is only needed if you do not otherwise already have 1090 IN (like on TAS-"A", if it ever is available).
Tom W.
SB Jim
Comancheguy,
It sure sounds right to me. There are many places where we will be outside the "service volume area" or whatever they're calling it. I saw it on my recent trip to Tucson. In my Garmin Pilot app I was receiving "air to air" but I was not receiving anything from a ground based station. I was in radar contact with ATC on a discrete squawk code at that time. I was in cruise flight at 11,500' MSL. A dual band receiver would gets you air to air inbound from either 978 or 1090 Out in addition to ground based transmissions from either. Regards, Jim |
Tom W's post above is correct.
So is Comancheguy's scenario, which posited that a ground TIS-B transmitter was not in range, so only air-to-air is available.
brou0040
We seem to get left out on the west coast being thought of as the few exceptions that may not be in range of a ground station. It's the same when people assume you'll be in radar contact, not so much out here. The places I can't get flight following are the places I'd like traffic in the cockpit the most.
Yes, agreed.
A lot of folks like to take the multiple lines of defense approach: 1. Keep your eyes outside looking for traffic (unless IMC). 2. Use flight following services from ATC. 3. Install an active traffic system. 4. Install an ADS-B system and get repeated data when in service volume areas There are other techniques as espoused by people on this forum and they're all good.
flybikeski
Groupie Joined: 26 Feb 2015 Location: Placerville Status: Offline Points: 68 |
So let me get this right. Air-to-air is not available with the single-band MLB100 - you have to be in range of a ground station. Being out of range of a ground station is quite common in the west. I was on a Flying Sams trip to Mexico with a group of six planes. A few of them could see each other which seems quite useful. With the MLB100 I would not be able to see any of them, correct? I was getting excited about the MLB but now it sounds like it doesn't quite do it for me. |
Well, there is the MLB-2xx coming out. It is dual band.
comancheguytoo
Thanks for replies. I think the answer would be air to air will work with the MLB-100 only if your bogey is 978 out.
Air to air will not work between two or more equally axp-340/mlb-100 equipped aircraft because they would transmit and receive on different frequencies. Examples of other brands: Freeflight guys (978 out and in) can see each other L3 Lynx guys (both out and in) see each other, and see everyone else Garmin guys (1090 out and both in) see each other, and see everyone else, but we don't see them I guess the point I was making was that Avidyne guys not seeing each other air to air seemed inconsistent, and I thought I might be missing something.
n7ifr
There are only two frequencies: 978 & 1090. For air-to-air, and no ground TIS-R repeaters, to receive both, you need ability to receive both (IN) frequencies...
Hence, the Avidyne combo TAS xxxA (with 1090 IN) and MLB100 (with 978 IN) will pick up both air-to-air, and when within a ground station range (FIS-R), your AXP340 1090 Out triggers both from the ground station, so you receive both as well. When out in the boonies (no FIS-R), with Air-to-air, the TAS "A" receives 1090 IN and MLB100 receives 978 IN, but someone else out there will only receive your 1090 OUT (AXP340) unless they also have Dual IN receive capability. Tom W.
Edited by n7ifr - 18 Apr 2015 at 7:09pm |
There are a lot of Avidyne customers who have no intention of spending the big $$$ to get a TASxxxA system. Folks are trying to figure out what makes sense to satisfy the 2020 mandate and get the best bang-for-the-buck TIS-B out of that. Had Avidyne had the option for a UAT-out, I would have far preferred that to the AXP340 1090ES-out that I ended up choosing. I think a lot of us low-and-slow folks think it's foolish to have a 1090ES-out transponder, but if you need one today and don't want to go Garmin...you don't have much choice.
Edited by MysticCobra - 18 Apr 2015 at 9:55pm |
MikeK
Groupie Joined: 16 Sep 2013 Status: Offline Points: 87 |
Tom, With the TAS-6xxA and the MLB-100, you could theoretically have the 1090 and 978 ADS-B IN bands *and* TAS for traffic that doesn't have ADS-B OUT yet. However, as I understand it, Avidyne currently has no way to combine the TAS unit and the MLB into a single, integrated traffic picture. You could connect the TAS unit to one display and the MLB to another, but that would (IMO) be really confusing. The L3 and Garmin products claim to provide dual-band ADS-B and TAS all integrated into a single traffic picture that incorporates data from all three sources.
Edited by MikeK - 18 Apr 2015 at 11:45pm |
n7ifr
...as I understand it, Avidyne currently has no way to combine the TAS unit and the MLB into a single, integrated traffic picture. You could connect the TAS unit to one display and the MLB to another, but that would (IMO) be really confusing. The L3 and Garmin products claim to provide dual-band ADS-B and TAS all integrated into a single traffic picture that incorporates data from all three sources.
[/QUOTE]
My last rumor control indicated that the TAS6XX"A" will synchronize both interrogated X'ponder traffic with 1090 IN ADS-B and display both on the 540... I would only "assume" with the MLB100, the added 980 IN would also be synchronized to block duplicate bogies. Maybe a comment from the Avidyne staff?? Tom W.
flybikeski
Is there a dual-band MLB2xx in the works? Because right now a dual-band Stratus or a dual-band iLevil and an iPad outperforms a 540 and an MLB100. Not to mention price. I really want traffic up on the panel, but (at least for my flying in the west) it needs to capture all traffic, not just when near a ground station. I do acknowledge certified equipment lags portables so I understand why Avidyne doesn't have it, but I hope they can show a reasonably affordable path with planned equipment or support of other equipment. |
flybikeski
I reread this thread and see that Steve J. did say they are planning dual-band as we get closer to the mandate. I guess I need to be patient.... |
SB Jim
There is no device made that captures all the traffic. |
brou0040
I'm not sure what the development timeline is for Avidyne's ADS-B equipment is, but I'd suggest that a dual-band IN solution be up next after the MLB100 and before the MLX200 or MLX210. They've been driving people towards the AXP340 out solution so those who went that route have no benefit from a MXL200 or MLX210 over an "MLB200" and will be stuck waiting again if they are looking for a dual band IN solution.
flybikeski
Was not looking for one of those. However seeing more is better than seeing less. (For me and my flying profile. A MLB100 looks great for many folks). Edited by flybikeski - 19 Apr 2015 at 3:55pm |
Gary T
Interesting Aspen Avionics website statement:
ARX200Dual-Band In ADS-B Receiver Certified ADS-B receiver for aircraft with a Mode S with Extended Squitter (ES) transponder and WAAS GPS installed. Transponder: Existing Mode S + ES GPS: Existing WAAS GPS Garmin GNS 430W, 530W, Free Flight 1201 Availability: Q3 2015 |
Gary-T
The ARX200 is the successor to the ARX100 -
the 100 was supposed to have been available this past summer....but, wait, it isn't. Nor is the ARX200. The ARX200 doesn't appear to accept the 540 as position source, not does it appear to accept the newest generation Garmin boxes. And the hook is, if/when it comes out - it will display on the Aspen but not on the Avidyne. The same is true - the MLBXXX will display on the Avidyne, but not the Aspen. They were supposed to be working together, following Capstone.
Edited by ddgates - 19 Apr 2015 at 4:42pm |
MikeK
I believe they have already stated (can't recall where at the moment) that it does not do this. You can have TAS-605A traffic (with 1090-IN and TAS) or you can have MLB-100 traffic (978-IN), but you cannot merge and reconcile the two. If you have a TAS-605A and you want to use the MLB-100 for FIS-B, you can, but you have to disable the TIS-B or send it to a different display.
The Aspen units are rebadged Freeflight units. They will be sold at a bit of a premium, but will not require an unlock code. Freeflight's units apparently will work too, but Aspen will charge an unlock code to let them work.
AviSimpson
Sorry for the delay in getting a response to this thread...
Right now, if you're looking for "dual band" traffic your best bet is the TAS6xxA and either the MLB100 or MLX series. The TAS-A will incorporate ADS-B traffic, when available, with the active traffic returns. It will also give you a more tailored protection zone around the aircraft and not just the "hockey puck". We've heard the request for dual band systems from a few different places. Just out of my curiosity, what are you trying to gain from a dual band system that a TAS system wouldn't provide? |
Simpson:
Not to split hairs, but if you do that TASxxxA and the MLB100, you will also need ADS-B out, e.g. the AXP 340. |
flybikeski
Affordability. I just plain can't afford TAS and I'm sure other pilots are in the same place. To say we should go out and get your TAS product is a little like telling a group of homeless people that the solution to their problem is that they should buy homes. Easier said than done. Edited by flybikeski - 20 Apr 2015 at 10:52am |
AviSimpson
David, You're absolutely correct. I went off of the presumption that ADS-B OUT was already being solved.
I have TAS and love it, and it does fill in all the gaps.
BUT it is quite expensive. Although I fly a lot in the US, being based in Canada it made sense for me, we'll never have TIS-B here. Simpson, what I think folks are asking for is to bridge the gap between 978 and 1090, when a ground ADS-R ground station is not in range. * Orest Edited by oskrypuch - 20 Apr 2015 at 2:57pm |
jblodgett
Groupie Joined: 24 Sep 2013 Status: Offline Points: 62 |
"what are you trying to gain from a dual band system that a TAS system wouldn't provide?"
We are trying to find a built-in solution that gives us air-to-air (broadcast) reception of all ADS-B signals without spending the minimum of around $15k it would take to do it with your TAS/MLB100 combination. Most of us are currently using Stratus or Garmin portable units with iPads and have that capability for well less than $2k. I know you have an interest in selling your TAS systems but it is just not realistic for you to expect people to follow that route. For that matter, I believe there really is no future for TAS systems. I would really like to see you come out with a dual frequency ADS-B receiver to interface to my IFD540/AXP340/EX600 avionics stack. Until you do, I will continue to rely on my Stratus/iPad combination. Edited by jblodgett - 20 Apr 2015 at 11:31am |
AviSimpson
Got it. I just wanted to know if it was an issue of feature sets or not. You're right a TAS isn't going to be for everyone and we know that. My point was that if you are going to be doing a lot of flying in an area that doesn't have nearby ground stations or has aircraft that don't need to participate in the ADS-B world, your best bet for supplementing your "see and avoid" is a TAS. Just a FYI, the MLX210 list price is $4,995 and the MLX200 list price is $3,495. |
AviSimpson
Unfortunately, we will never compete on a price level with a stratus/Foreflight configuration in a panel mount solution.
While you are right, that a dual band transceiver might solve some of these issues and possibly at a lower cost (L3 Lynx MSRP ranges from 10k to 15k and Aspen AXR200 $4-5k) than a TAS setup, it might not give you the full traffic picture. It's definitely something that I will bring up to the team as another line of the MLX series. Though it probably won't be at a Stratus/Foreflight price.
jblodgett
Thank you for your response. I do not expect that any certified installed solution be similar in price point to the Stratus/iPad solution but it needs to be far less than your TAS/MLB solution. I believe there are vanishingly small advantages to the TAS approach that do not justify its cost. Not for me at any rate.
Added comment: Your MLB100 costs $2495. That seems reasonable given all the ridiculous hoops the FAA makes you jump through. But why should a dual frequency version cost much more than that? Edited by jblodgett - 20 Apr 2015 at 1:37pm |
flybikeski
AviSimpson, I don't think anyone on this forum expects Stratus pricing on certified equipment, so no worries there. I think it will be pretty clear in the market (FreeFlight, Aspen, etc.) what certified dual-band ADS-B receivers should be priced at. I think the point is your customers want one. Maybe more so than the MLX2xx products. But I'm just guessing at that... |
I think he is right.
What we would really like, though, is a device which talks across platforms, i.e., Avidyne MFD and Aspen MFD. Aspen and Avidyne collaborated on the driver software for the DFC-90, why not align so that each company's ADS-B box displays on the other company's MFD? Can it really be that hard?
Edited by ddgates - 20 Apr 2015 at 1:38pm |
AviSimpson
I don't think what's being asked for is outrageous. I'll do some research our end so we can see what it would take to get it added to a platform like the MLB/MLX series.
