Feature Request: recent frequencies dups |
Posted: 23 Feb 2015 at 10:39pm |
On the list of recent frequencies tab, can you suppress the duplicate listing of frequencies? Would make the list even more useful.
Okay but do you have an example or two? I'm not sure I've seen any dups before.
Oh, never mind. I see you used "Recent" tab. Got it.
Rog.
Still in the offing? * Orest
I just looked into this and it appears to me that it's working per design. Each entry in the recent list contains frequency, facility identifier, and call sign. So it's entirely possible to have two entries in the list with the same frequency, but different identifier and/or call sign.
Are you reporting a bug or suggesting that the design should change such that the recent list considers only frequency when determining whether an entry is already in the list?
When I reported it (years ago now), I noticed that there would often be multiple instances of the same station, with the same frequency, as multiple entries on the list. Wasting a slot. So that may well have been fixed. If so, great, apologies for the comment. * Orest
Edited by oskrypuch - 08 Feb 2022 at 1:24pm |
I just did a quick test this morning and it seemed OK and a glance at the code looked all right as well. I'll do a little more testing to see if I can reproduce it.
KIM
Adding another frequency feature request:
Can you add the identifier in the Com Preset List. Klaus
Klaus
I'm not sure how that would work. Lots of frequencies are common, so the facility name would vary depending on where you are.
