  New Posts New Posts RSS Feed - Feature Request: add AFTER waypoint for restricts
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Feature Request: add AFTER waypoint for restricts
    Posted: 26 Mar 2015 at 6:40pm
Often needed on SIDs and such. I'm proposing that the "before" field should be made togglable as before/after.
Before should remain the default.
Edited by oskrypuch - 26 Mar 2015 at 11:23pm
twalterhome3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twalterhome3 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 5:50pm
I've never seen a procedure with an altitude restriction AFTER a waypoint
can you post a link to one (AIRNAV or similar?)
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2015 at 10:08pm
They are reasonably common in complicated SIDs. Have a look at Kennedy1, on the Breezy, Bridge and Canarsie climbs you are given a crossing altitude restriction at a certain DME after CRI. The text detailing that is on page 2.
http://155.178.201.160/d-tpp/1503/00610KENNEDY.PDF
http://155.178.201.160/d-tpp/1503/00610KENNEDY_C.PDF
Edited by oskrypuch - 27 Mar 2015 at 10:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 8:25am
I didn't realize.  Thanks for the enlightenment.
Just added to future features database.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 8:56pm
Steve:
Here's my request.via
Set up a FOB-mediated mechanism by which users can exchange datablock configurations; e.g., GRING could send his optimum configuration via data file and it could be loaded through a FOB.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:11pm
10.1.0.0 accomplishes what you want. You can save user settings, user waypoints, device configuration, and data blocks. I've done this quite a bit lately swapping boxes around IFD #1 to IFD #2 and vice versa. I also had one of mine rebuilt so I was able to restore settings. These are stored as files on your USB memory stick as files and I could email them to you as an example.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:15pm
When I get 10.1.0.0, Geoffrey, I'd like to do that.
ADD and all that, impatient to go through the setup up one by one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2015 at 9:24pm
It'll cost ya...
I sent them to your email. I did not include the device configuration since that will just mess up your installation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 9:28pm
Still in the hopper?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2022 at 9:03am
It's still in the "future features" list, but it hasn't come close to making the cut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2022 at 1:17pm
Understood.
if the proposed feature list ever runs low, I'm ready to fill it back up!
Edited by oskrypuch - 08 Feb 2022 at 1:19pm
This page was generated in 0.142 seconds.
