  New Posts New Posts RSS Feed - New encoder required for 340 install?
flybikeski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flybikeski Quote  Post ReplyReply Direct Link To This Post Topic: New encoder required for 340 install?
    Posted: 16 Apr 2015 at 11:22am
I received a quote for a install and the shop said, "you'll probably need a new encoder too" without even knowing what I have.  I believe I have an encoding altimeter with grey code.
Are folks generally getting a new digital encoder with their installs?
Is the digital (RS-232 interface) better in some way to the old grey code?
Or does he just want to deal with less wires? (but then he has to tie into the pitot/static system and figure out where to put the unit - I guess no problem for these guys).
edanford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 11:57am
Nope,   I had to change nothing from my encoder.  ( I had a KT76A transponder)
If you have a KT76A,   you can pull it out and plug in the AXP340 and it will work mode S.
I have a grey code encoder
The chassis  for the transponder has to be swapped to upgrade to ADSB out for the GPS signal connector but that is it.
Ed
roltman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 12:19pm
I had a newer Sandia encoder, but was using the only grey code with my old GTX330.
I did have it rewired when I did my 340 install.  I don't recall that is required though, maybe for 1090 ADS-B?
The Sandia had 2 RS232 and 1 grey code outputs IIRC.
I sent the grey code to my STec alt-preselector. I sent one RS232 to IFD540 #1 to have it cross talk to IFD540 #2.  I sent the other RS232 to the 340 which has a parrot feature which parrots the output to the MLB100 ADS-B Input.
The RS232 is higher resolution.  I think grey code is 100' resolution while RS232 can depending on the encoder have 1' resolution.
Edited by roltman - 16 Apr 2015 at 12:21pm
SB Jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SB Jim Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 12:34pm
I had an encoder as well as a serializer (Icarus 3000U?).
The serializer was required for my CNX 80 (can't recall why).
For unknown reasons the unit would be very accurate at times and 200 feet off other times. I asked my shop to rip them both out and put in one good one.
It's been spot on since AFAIK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote flybikeski Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 12:34pm
Thank you.
Yes, I saw the 340 could output and wondered if the 540 could take its altitude information from the 340 via RS232 instead of splicing from grey code.
The MLB100 needs altitude?  Why?  And if it does why can't it get it from the 540 which it is connected to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote roltman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2015 at 12:59pm
I think we chose the AXP340 altitude output because there was another transponder connection needed to be sent to the box.
Thinking a little more about it, traffic target adjustments may be the reason for the pressure altitude input.  I'm not an ADS-B protocol expert, so take this as a WAG.
Kentucky Captain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kentucky Captain Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2015 at 6:29pm
When they did the install they left the original encoder in and it worked.  Somewhere into the second test flight it decided to give it up and they had to install a new one.  Fortunately we were still at the avionics shop and they only charged us for the encoder (no labor).  If you have an ancient one like ours was it might be cheaper to replace it now as opposed to later.  We did the same thing with the ELT and fuel sending units.  We had an old 121.5 elt. A new 406mhz one is under $600 and it was around $400 to install since they had the seats, carpet, and floor panels up.  They also had to mount the remote panel for it up front.  They were installing a new panel anyway so the costs were minimal.  Doing it later would have cost another $1000 in labor.  We had a JPI EDM900 installed too and it is very picky about the fuel sending units. We had those rebuilt since they had it all apart.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2015 at 8:07am
Our plane did not need a new encoder.  The old gray code encoder is connected to the AXP 340 transponder.  The transponder provides the serial data to the IFD 540 and the Icarus SAM.
And we also replaced the ELT with a 406 MHz unit.  As long as everything is torn apart and we're spending that kind of money, what's another AU?
This page was generated in 0.121 seconds.
