  New Posts New Posts RSS Feed - IFD440 layouts with 540/440 combo?
chflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Topic: IFD440 layouts with 540/440 combo?
    Posted: 28 Jan 2016 at 2:03pm
With the IFD440 out for a while now, there must be a few of you out there with an IFD540/IFD440 combo installed. Any comments, suggestions, experience with setting up the IFD440 screen layout in that situation?
Is the map view really useful given the much larger IFD540 real estate? An obvious option would be to have the FMS page open with the flight plan. Any others that are useful?
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2016 at 4:04pm
I find myself using the 440 very often as a data entry device and FMS manager in conjunction with the 540 as the primary map display.  Unless the ability to quickly and easily disable/enable the device linkage becomes available, I have not found it very useful to have dual maps.  If the linkage was selectable as one-way or configurable data sharing, the situation might well change.
But having a fully interactive FMS is an excellent use of the 440.
David E.
Cessna 182 RG II
This page was generated in 0.035 seconds.
