  New Posts New Posts RSS Feed - Extended Centerline Intercept
TomH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomH Quote  Post ReplyReply Direct Link To This Post Topic: Extended Centerline Intercept
    Posted: 29 Feb 2016 at 8:53pm
So I've read the user guide and used the simulator and feel like I understand this function but in the plane I can't quite figure it out, maybe someone can help. I've got dual IFD440s and Portrait 5000 PFD/MFD in a Columbia. Anyway when flying VFR I'll often just be direct-to-destination. Using the sim and switching to OBS mode I can create a "radial" off of the destination airport the same as the runway heading and fly an intercept either manually toward the magenta line or in NAV mode with the autopilot.  In the plane however the 440 doesn't behave that way I believe because of the external EFIS/CDI. How do I do this via the external EFIS?  Perhaps it's the same with an Aspen which I know many people have... or maybe I have this all wrong. Here's my example from the simulator:
440
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Feb 2016 at 9:22pm
When I place my IFD into OBS mode, I can change the course (radial) by twiddling the CRS knob on my ASPEN, or by turning the "OBS" (top right) knob itself.
What happens when you turn the CRS knob on your CDI?
Edited by oskrypuch - 29 Feb 2016 at 9:24pm
GaryB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaryB Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:27pm
I'm having the same issue. After the switch to OBS turning the nob changes back to gps mode.
Cirrus with an exp 5000.is there some way to dial in a radial in gps mode?
Gary
TomH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 4:29pm
That's the problem, I don't see how to do that on an Entegra EXP5000 PFD. Twisting the IFD knob once OBS is selected doesn't do anything (like it does on the SIM). Perhaps a config issue on the IFD?
clydeps View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clydeps Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2016 at 1:28am
Use the left hand knob. You know, the one that you never use.
This page was generated in 0.057 seconds.
