  New Posts New Posts RSS Feed - intersection names
intersection names
jblodgett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblodgett Quote  Post ReplyReply Direct Link To This Post Topic: intersection names
    Posted: 10 May 2016 at 9:17am
How do you turn on intersection names?  On the map set-up page it looks like you should be able to put a check-mark next to intersection names but I can't figure out how to do that.
Thanks in advance,
Jim B
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 9:53am
To turn the intersections on, it's located on the AUX Page under "MAP Setup" LSK. You can use the inner knob to highlight the blank space after "Intersection" and push in on the right knob to have the check mark appear under "Show Label". There is some guidance on Page 4-34 on the IFD540 Rev02 Pilots Guide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblodgett Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 10:00am
Thanks.  The "push in the right knob" was the part I was missing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2016 at 10:19am
As long as the Nav Priority slider is not set to "off", the checkmark will show when you push.
