  New Posts New Posts RSS Feed - Preferred vertical speed rate / FMS Setup Page
bradthepilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Topic: Preferred vertical speed rate / FMS Setup Page
    Posted: 09 Feb 2017 at 3:05pm
So I love the TOD callout feature, but the default of 500' fpm is a bit low and I'd like to change it.   I see references in the documentation to changing the default on the "FMS Setup Page" but don't see the setting when I go there via AUX->Setup->User Options.    I'm clearly looking in the wrong place, but not sure where to find it.
Any suggestions from the community's wisdom?
Thanks!
Brad
Brad Benson
RV-6A N164BL
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 3:23pm
You're on the right page and tab. The decent rate selection is under the FMS Setup. Press the LSK until you get to the FMS Setup view (it switches between MAP Setup and FMS Setup).
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 3:26pm
Wow, it's like finding a secret room - so cool!
Thanks!
-Brad
Brad Benson
RV-6A N164BL
AzAv8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 8:36pm
And the response was not "I see no cave here."
(Raise your hand if you know where that came from.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 10:07pm
"You are standing at the end of a road before a small brick building."
Brad Benson
RV-6A N164BL
MysticCobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 8:21am
What happens if you try to fly to the XYZZY waypoint?
Gring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 8:32am
The original text based adventure game for the IBM PC back in 1983ish
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradthepilot Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 9:23am
It predates the IBM PC by a fair bit, actually.
Brad Benson
RV-6A N164BL
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 10:07am
I remember playing that on a lineprinter console attached to a PDP-11, in the seventies!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 2:24pm
https://en.wikipedia.org/wiki/Colossal_Cave_Adventure
Edited by MysticCobra - 10 Feb 2017 at 2:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 7:09pm
I remember it from the pre-PC days too.  I didn't realize it still had a life!   I might have to download a copy to reminisce.
Paul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Paul Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 10:44pm
I used to have a copy of the source code.  I worked in the building where the PDP-10 (later called DECsystem 10) was manufactured.  I was a software guy - worked on the FORTRAN compiler and run time library and linker, among other things.
This is getting way off topic, but I will say that the any of the IFDs has more processor power and memory than the biggest PDP-10 mainframe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 12:09am
Available for your android phone or tablet!
https://play.google.com/store/apps/details?id=com.ecsoftwareconsulting.adventure430&hl=en
A full play through on youtube (spoiler alert), appears to be on a DOS machine:
https://www.youtube.com/watch?v=O3etkSoHrR8
Edited by oskrypuch - 11 Feb 2017 at 12:12am
This page was generated in 0.133 seconds.
