  New Posts New Posts RSS Feed - IFD100 - change map view
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 - change map view
    Posted: 18 May 2017 at 8:41am
I believe I read the solution here somewhere, but can't find it now.
On the IFD100, how do you change between the HDG/Track UP, 240* UP, North UP views, akin to click the right IFD540 knob in Map view?
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:05am
Press the "enter" button.
zman520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zman520 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:39pm
And how do you change the "Map Settings" in Aux? i.e. The declutter ranges specifically. Since there is no right hand knob I can't change the settings. Touching on the individual fields has no effect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 9:44am
Right now, there is no way to change the MAP settings on the IFD100. Since, as you alluded to, the code is framed off of the panel IFD code and the panel IFD code for the AUX page Map settings don't support touch, we will have to make some changes to support it. It's on the roadmap to add the support for it.
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 1:02pm
Would you change the IFD software to allow touch screen on the AUX page? I found myself wanting touch on the AUX 540 so it'd be nice if it was there rather than just in the IFD 100.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 3:30pm
Eventually, it's much easier to do on the IFD100 first. I will add it to the candidates for releases but it will be 10.3 at the earliest.
Pulurope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pulurope Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2018 at 2:16pm
Good afternoon Simpson - Has there been any update to allow for changes to the map settings in the IFD 100 mobile app?
This page was generated in 0.234 seconds.
