  New Posts New Posts RSS Feed - Max number of waypoints on map??
pburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Topic: Max number of waypoints on map??
    Posted: 12 Sep 2017 at 4:44pm
I just entered a flight plan with 83 waypoints, including the origin and destination.  Only the first 68 waypoints are visible on the map.  However, if I do a Direct-To the 5th waypoint, five more waypoints will show on the map toward the end of the flight plan.  If I do a Direct-To the 15th waypoint, all the remaining 68 waypoints will be seen, but not the first 15.
Is 68 the maximum number of waypoints that can be shown on the screen at one time??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 12:06pm
Sure sounds like it.
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2017 at 3:48pm
There is no fixed waypoint limit. There is a limit on storage size however. As an example, a hold in a flight plan is something like 5 bits whereas a waypoint might be only 2 bits. We only have x bits of space available for storing a flight plan. When you go direct to a waypoint in your flight plan it frees up some storage.
This page was generated in 0.066 seconds.
