bluetooth keyboard charger cable |
Post Reply |
Author | |
psimpson
Groupie Joined: 23 Oct 2015 Location: Hays KS Status: Offline Points: 72 |
Post Options
Thanks(0)
Posted: 09 Jan 2018 at 10:49pm |
anyone try to charge a Stratus while using the cable that charges the bluetooth keyboard? I can plug my cable into the USB charger in the plane and it works fine but if I use the cable that charges the keyboard the charge light flashes red on the Stratus.
oskrypuch
Post Options
Thanks(0)
Flashing red on the Stratus means inadequate amperage.
If you want to charge two devices simultaneously, you need to get a better quality dual 2.4A usb charger, like the Anker units. About $10 on Amazon. https://www.amazon.com/Anker-PowerDrive-Charger-Bluetooth-Headsets/dp/B00VH84L5E/ref=sr_1_9?ie=UTF8&qid=1515592103&sr=8-9&keywords=anker+samsung+charger You can also use one of their power packs. * Orest Edited by oskrypuch - 10 Jan 2018 at 9:02am |
HenryM
Senior Member Joined: 13 Oct 2017 Location: Texas Status: Offline Points: 486 |
Post Options
Thanks(0)
It could be that the cable conductors are not big enough to carry the current the Stratux needs to operate. The Stratux is a big power hog. It uses more power than an iPad and is very sensitive to any voltage drop caused by the slightly higher resistance of the skinnier cables.
psimpson
Post Options
Thanks(0)
I think that is what is going on. You have to have a good quality wire and some amps to get it to charge.
oskrypuch
Post Options
Thanks(0)
It is very unlikely that the cable is much of the issue. Any USB A/micro power cord will carry at least 2A without trouble.
Clearly the USB unit can supply the Stratus, but not both simultaneously. If it is a plug in charger, $10 upgrade to the Anker, and problem is solved. * Orest Edited by oskrypuch - 10 Jan 2018 at 9:32pm |
psimpson
Post Options
Thanks(0)
No- it won't charge (blinks red) whether the keyboard is plugged in or not. I have one of the hi-amp usb chargers installed in the plane. Also I feel some heat where the connectors plug into the charger wire going to the Stratus.
oskrypuch
Post Options
Thanks(0)
So just plugging an unconnected second cable into the USB charger, causes the Stratus to blink red, but it charges fine when only it is plugged in? That is really odd. Perhaps the charger downrates one or both receptacles if it detects two USB A plugs? Did you try swapping which USB slot the Stratus is plugged into? Are you using the USB C charging cord that came with the Stratus? This is the Stratus2s? * Orest Edited by oskrypuch - 11 Jan 2018 at 9:17am |
LANCE
Senior Member Joined: 06 Dec 2014 Location: TEXAS Status: Offline Points: 277 |
Post Options
Thanks(0)
Make sure it's not the cord receptacle on the Stratus - those are notorious for bad connections and failing. (I use my Garmin GDL39 3D over Bluetooth for Foreflight and I like it much better than the Stratus.)
HenryM
Post Options
Thanks(0)
Just to make sure I understand., you are plugging in just the Stratus. If you use the Stratus cable, the unit works, but if you use the keyboard cable, the Stratus doesn’t work. If so, it is likely the cable causing too much of a voltage drop. The keyboard cable is fairly thin.
psimpson
Post Options
Thanks(0)
Yes I think the keyboard cable is to thin. I'm not using the black cable that came with the Stratus but it's a fairly expensive one and works fine unless the Avidyne charger cable is plugged in first. Anyone else having this happen?
Royski
Groupie Joined: 26 Feb 2013 Status: Offline Points: 87 |
Post Options
Thanks(0)
My Stratus 2 had some weird charging issues. I opened it up and found one or two bad solder joints on the circuit board where the micro USB socket was attached. I think I fixed it but haven't gone flying with it yet. If the charging status changes when you wiggle the cable near the charging port, I reckon you have the same problem.
psimpson
Post Options
Thanks(0)
I've had my Stratus already fixed due to this issue. It has to be a good quality charger wire or as you say it won't charge right.
However this isn't my problem, the Stratus will never charge if I have the keyboard charging wire plugged in first. It only blinks red. I have an app on my phone that detects milliamps from the charger, I will compare how it charges with and without the keyboard charging wire on my next flight and report my findings
psimpson
Post Options
Thanks(0)
According to an app on my Droid it charges about half (600ma vs 1200) as much when going thru the Avidyne wire first. Just as I suspected, the wire is soaking up some of the current.
oskrypuch
Post Options
Thanks(0)
Do you have a spliter of some sort on the end of USB A / mini cable, and then daisy chaining the Stratus cable on that? That would be a really unusual setup. Why, and how, would you connect the Stratus USB A to USB C wire to the USB A/mini wire that goes to the keyboard? The way I read your posting is that you had both USB A plugs (the mini connecting the keyboard, and the USB C attaching to the Stratus), both running back to the two outlet USB cigarette plug adapter, and it was not making any sense. * Orest |
psimpson
Post Options
Thanks(0)
Yes- that is the charger wire that came with my keyboard. It has the USB mini and a USB female so you can plug another usb cable into that. What did yours come with?
compasst
Senior Member Joined: 22 Feb 2015 Location: Akron, OH Status: Offline Points: 169 |
Post Options
Thanks(0)
I know for certain that the selection of USB charging wire makes a difference. I use an Anker Powerport 4 with Power IQ. It automatically senses what the plugged in device can accept and gives it the proper amperage flow for charging, lighting a light when it is in its fastest charge mode. I know that the cable used can prevent the light from lighting when charging my Android phone or my iPad. Therefore, I use Anker 6-foot cables and Anker dual-port adapters (high amperage on both ports) in the various airplanes I fly - always works, always charges fast (particularly an iPad running Foreflight), and never creates noise on the aircraft's audio.
oskrypuch
Post Options
Thanks(0)
Ah, OK, that all makes sense now. I don't use that cable, not sure I even got one. I just use a spare USB mini that I carry in my flightbag. * Orest |
Post Reply | |
Tweet
