  New Posts New Posts RSS Feed - Arinc 429 out format for Stec-55x gpss
moakley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote moakley Quote  Post ReplyReply Direct Link To This Post Topic: Arinc 429 out format for Stec-55x gpss
    Posted: 11 Mar 2018 at 5:27pm
Is anyone running a 540 with a Stec-55x?  My gpss roll stearing went away, I think abou the time of my 10.2 upgrade.  I've asked a couple of shops about this and also sent a ticket in to Avidyne support.  So far, .... crickets...  BTW my 540 wouldn't update in the aircraft so the unit had to be exchanged,  and thus the setting that worked before, are gone.  Raw nav still works fine,  if not so precise.  My HSI is a  KCS 55.
TIA
Myron Oakley
Blue Sky Aviators, LLC
Turbo Twin Comanche N8689Y
HenryM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 5:38pm
I have an STEC-30 and it continued to work fine after the 10.2 upgrade. I’ll see what my settings are when I get the plane back from annual next week. I do t think the 10.2 upgrade has anything to do with it. Your new unit may need new settings, or perhaps something else is having a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote moakley Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 6:09pm
Unfortunately my number 2 out isn't even turned on.  Both one and two are wired to the 55x.  Now,  I'm not totally sure about a stec-30 is you may have a gpss converter on that one.  The 55x is designed to take arinc 429 gpss without the need for a converter.  Also ran fine for years off a G530.
Myron Oakley
compasst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote compasst Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 6:18pm
TIA
Call Christine Evans at Avidyne tech support. Speak to her personally. If she doesn't have an answer directly, she will help get the issue resolved. I have experienced two issues with loss of features - and they were fixed with a software load that Christine had created for my situation. The load took a second or two, then the reboot, then the features (WiFi/BT and 500' callout) were back.
AviTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviTJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 4:57pm
Myron,
I just sent you an email.  For posterity's sake, I will answer here so if anyone else has this issue it will give them some idea of where to check.
For GPSS roll steering to an STEC 55x, the IFD 429 output needs to be configured for one of the GAMA 429 varieties.  Straight ARINC429 will not work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote moakley Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 5:02pm
Got it, Thanks,  will re-config and give it a try.  Will post results here.
Myron Oakley
Post Options Post Options   Thanks (0) Thanks(0)   Quote moakley Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 8:12pm
Myron Oakley
