  New Posts New Posts RSS Feed - Garmin annunciator
Garmin annunciator
phkmn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Topic: Garmin annunciator
    Posted: 08 Feb 2013 at 10:56am
What happens to the Garmin annunciator in Beech aircraft with the 540?  Continues to work as with the Garmin 530W?  Or goes dead/obsolete?
PH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2013 at 5:02pm
You *should* be just fine.   I say "should" because I'm not sure what annunciator you have installed.  Do you know the model number or can take a picture of it?  Did it come from the Beech factory already installed or was this an aftermarket mod?
All of the annunciators that are identified in the G530 Installation Manual are supported by the IFD540.  We have most of them installed in our integration lab and we drive them every day.  Same holds true for our company test aircraft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2013 at 9:26pm
I've no idea what brand it is:  it was installed with my G530W by the previous owner as required by the panel layout of the Beech V35B.  If you're supporting the major models, I'll hope for the best, thanks.
PH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2013 at 9:30am
It should be fine but if you send me a picture (sjacobson@avidyne.com), I might be able to id it and give you a 100% confident answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2013 at 4:27pm
Picture sent, thanks.  It's sitting just above the altimeter.
PH
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2013 at 4:34pm
Got the picture. Will try to id the unit on Monday after digging out from the snowstorm up here in MA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 9:37am
That's a Mid Continent MD41-1488W annunciator and yes, the IFD540 fully supports it.  I just sent you an email with a picture I took this morning of that exact annunciator hooked up to, and being driven by one of our lab IFD540s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phkmn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 4:25pm
Got your email; thank you!  Good news.
PH
