  New Posts New Posts RSS Feed - OBS transitioning
OBS transitioning
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: OBS transitioning
    Posted: 08 Dec 2013 at 1:13pm
Quote  Can you halt the sequencing through an OBS'd waypoint, and prevent it from transitioning to GPS guidance further along on the next route segment?  As long as you set up the OBS so that it's a "TO" course, the sequence will happen and cannot be disabled (halted).  If you dial it so that the geometry is "FROM", then you won't sequence.
One of the major uses for holding the flightplan from progressing through an OBS'd waypoint, is to create a semi-automatic hold at a point on a flightplan, mixing HDG for the outbound, and NAV back for the inbound. Of course that is no longer necessary with automatic HOLDs in the 540 (thanks for that!)
But, there are some other uses for this. Perhaps you can consider providing an LSK to stop sequencing in future releases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2013 at 2:10pm
We'll see.  We felt very strongly about the current design.   It'll come up again during next release definition meetings but I wouldn't "hold" your breath on that one......
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2013 at 2:24pm
Hmm. Well, maybe in practice on the IFD540 it truly won't be needed any more.
This page was generated in 0.148 seconds.
