  New Posts New Posts RSS Feed - Volume too low
Volume too low
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Topic: Volume too low
    Posted: 13 Mar 2015 at 5:53pm
Is there any way to adjust the volume of the AXP-340?
I find that even with my headset turned all the way up that the altitude alert coming from the AXP-340 is very quiet.
Gring View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 7:19pm
Go into the maintenance mode by pressing the Function key while turning on power.  Then scroll through the settings until you get to Volume.  Raise the volume here, it will output a test with each change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2015 at 1:09am
Thanks, didn't think about the maintenance mode...
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 12:11pm
I'll need to look into this more.  The volume was set to 6, I increased it to 10, but the test audio didn't increase much.  It was noticeably louder if I turned the intercom off.  I have a feeling that my shop set the volume without the intercom on.
