  New Posts New Posts RSS Feed - Dual Antennas?
Dual Antennas?
flybikeski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flybikeski Quote  Post ReplyReply Direct Link To This Post Topic: Dual Antennas?
    Posted: 21 Mar 2015 at 10:49pm
My annual is coming up and I'd like to pre-wire in top and bottom antennas for the MLB-100.  It looks you use standard blade-type DME/transponder antennas.
1. I will probably take out my King DME when I put in the 540.  Can I just use the blade DME antenna as is (on bottom of aircraft)?
2. For dual antennas, do you just use a coax T connector to tie them together?
Thanks!
Gary T View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary T Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2015 at 9:17pm
Probably Steve is busy answering IFD540 issue questions.
The MLB100 brochure shows only one RF antenna connector and the suggested price of the unit
likely means that it will not have two antenna diversity reception (top and bottom).  It makes sense to reuse the DME bottom antenna for ADS-B IN reception.
Gary-T
This page was generated in 0.082 seconds.
