  New Posts New Posts RSS Feed - Audio Squeal on 125.00
Maurice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice Quote  Post ReplyReply Direct Link To This Post Topic: Audio Squeal on 125.00
    Posted: 25 Oct 2015 at 10:40am
I have an IFD540 GPS/NAV/COM and an AMX240 audio panel.  Whenever I have 125.00 as the active com frequency I get a loud audio squeal.  This stops when I transmit, or when someone else transmits and the "Rx" indicator comes on.  In other words, the squeal happens whenever the channel is quiet.
At first I had experienced this only when I land at Palo Alto (KPAO) which uses 125.00 for ground, so I assumed it was something peculiar with KPAO's transmitters.  But recently I landed at Sacramento Exec (KSAC) which also uses 125.00 for ground and it happened there too, so I now realize the problem is on my end.
Has anyone else experienced this?  Thanks for input and suggestions.
Maurice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2015 at 11:11am
Do you have an ASPEN?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2015 at 11:32am
Orest,
Thanks for the reply.  No Aspen.  Most of the panel is 1982 vintage Cessna and King, including a KFC 200 Autopilot with HSI and Flight Director.  I also have a Garmin 496 in an Airgizmo dock, a Horizon electronic tachometer, a yoke-mounted iPad, and a Stratus II in the back.
Maurice.
ac11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac11 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 5:41am
What was the resolution to this?
Orest, why would the Aspen make a difference?
Maurice Gunderso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice Gunderso Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 7:47am
AC11, thanks for reminding me to post the outcome.
After I posted the problem, I discovered that when 125.00 was tuned in the active position, and not transmitting, the loud squeal was also received on my No. 2 com (a King KX155) if it was tuned to 125.00. So that pointed to the IFD540 as the source of the interference.
My avionics shop took the IFD540 out of the airplane and powered it up on the bench. Sure enough, when 125.00 was tuned in the active position, and not transmitting, the loud squeal was received on a handheld transceiver tuned to 125.00. The handheld could be 20 to 30 feet away and still pick up the squeal. This confirmed that the problem was originating in the IFD540.
The avionics shop discussed this at length with Avidyne. After some more tests, Avidyne declared they had never seen this problem before and did not understand what was causing it. Avidyne sent a replacement IFD540 and had my original one sent back for diagnosis. The replacement IFD540 does not have the problem. I assume the original one is causing some head scratching at the factory.
So from my standpoint, Avidyne resolved my problem quickly and satisfactorily. What could be better than swapping the unit at no charge? Whether they have now diagnosed the problem in the original unit, I don't know and may never learn.
Regards, Maurice.
Edited by Maurice Gunderso - 23 Aug 2016 at 7:49am
Maurice Gunderson
M: 415-810-4559
ac11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac11 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 3:28am
Thanks Maurice for the follow up. I'm still curious about Orest's thought process with the Aspen.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 8:34am
Jeff
So am I, that was from last year. I vaguely remember reading about an odd COM interaction on ASPEN panels, although not specific to IFDs, but can't remember the specifics now.
Edited by oskrypuch - 24 Aug 2016 at 8:38am
MarkZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkZ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 8:34am
I'd like to second great service with Avidyne's staying on the issues until they are resolved.
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 11:56am
Do you still have an old 121 ELT?  If so remove it fro the airplane and see if the 125MHX signal is still there.
pburger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 2:41pm
I encountered a loud, pulsating, garbly tone or squeal on 125.0 a month ago, and then again yesterday.  I first noticed it on the IFD-540, and tried my trusty KX-175B, and heard the same exact squeal.
I was able to isolate the problem yesterday.  It is coming from my Stratux DIY ADS-B receiver.  As soon as I powered down the Stratux, the squeal stopped on both radios.
I plan to add shielding to my Stratux case to hopefully minimize the problem.
Edited by pburger - 25 Aug 2016 at 2:42pm
