  New Posts New Posts RSS Feed - Transfer data block setup from sim to IFD
1964-m20e View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1964-m20e Quote  Post ReplyReply Direct Link To This Post Topic: Transfer data block setup from sim to IFD
    Posted: 01 Mar 2016 at 12:11pm
I just got my plane back form the IFD540 and APX322 install and want to transport the setup I have in the simulator to the airplane.
I know there is a way to do it in the maintenance mode of the sim but not sure.  I could use some help.
Dlesh123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dlesh123 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 7:47pm
There is a thread on this forum that talks pretty extensively about this. Be careful, we tried that and setup info from the sim was transferred, totaled screwed up our 540. I believe you have to transfer your 540 settings to the sim first and then you can transfer changed sim settings back to your airplane.
A lot of discussion here: http://forums.avidyne.com/forum_posts.asp?TID=788&title=ifd-540-440-uploads
Edited by Dlesh123 - 01 Mar 2016 at 8:20pm
Bad1996 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bad1996 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2016 at 10:01pm
It takes two minutes to write down what you have in the sim ? Three or four minutes to put that into the 540 ? Why risk causing issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 8:50am
I took some quick pics of my main and setup screens, and keep them in Evernote, just in case. Plus, I always have that data to refer to, even if not in the plane.
Edited by oskrypuch - 02 Mar 2016 at 12:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1964-m20e Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2016 at 11:25am
thanks
I will just set up the 540 in the plane.
