IFD440s take a long time to connect to GPS
URL: http://forums.avidyne.com/forum_posts.asp?TID=2170
Printed Date: 04 May 2024 at 2:35am Software Version: Web Wiz Forums 12.01 - http://www.webwizforums.com
Topic: IFD440s take a long time to connect to GPS
Posted By: D-EACY
Subject: IFD440s take a long time to connect to GPS
Date Posted: 02 Apr 2021 at 4:29am
I got two IFD440s in 2018 for my SR22. I really like them but after 1.5 years they started to take a long time to connect to GPS. I sent the logs to Avidyne and they told me that the "GPS boards were defective" and from a bad batch and they exchanged them for two other units of the same vintage.
Now it started again, sometimes it takes up to five minutes until i get the ownship signal. The GPS signal page inly shows three satellites for the first three or four minutes. The #1 unit also takes much longer to load the database than #2.
Any ideas?
------------- 2006 SR22-G2 DFC90 IFD440
Posted By: D-EACY
Date Posted: 12 Apr 2021 at 4:14am
Nobody but me has this symptom? Really?
Date Posted: 12 Apr 2021 at 7:43am
mine have been stable and only take slightly longer when the plane sat for awhile.
Posted By: D-EACY
Date Posted: 12 May 2021 at 4:31am
Is it normal that after five minutes the GPS status page looks like this? The moment I took the picture my iPhone showed 20 satellites in sight ...
Date Posted: 12 May 2021 at 8:01am
No. If you haven’t flown in awhile, it may take slightly longer to acquire satellites, but even then, it is less than a minute.
Date Posted: 12 May 2021 at 9:07am
Do you have an active FPL? My experience is that GPS acquisition is quicker and more stable once an FPL has been entered and activated.
Posted By: D-EACY
Date Posted: 13 May 2021 at 5:06am
No, there was no active FPL in this case. I do not use a FPL when doing local flights.
Both units were exchanged by Avidyne some months ago for the very same reason. Avidyne wanted me to download the logs back then and then they told me that "both GPS boards are defective".
But now, again, it sometimes takes more than 5 minutes until GPS is locked on. (I fly 2 times per week most weeks)
Posted By: PA23
Date Posted: 14 May 2021 at 10:18am
How old are the GPS antennas? The WAAS antennas are powered units and are not passive devices. I've had one on my plane and one on a friends plane go bad. The symptoms were slow to acquire a lock, occasional loss of position, and eventually it wouldn't get a position at all.
Posted By: psimpson
Date Posted: 17 May 2021 at 9:08am
Once in a great while one of mine won't find any thing and I have to reboot. Otherwise mine always have a fix before I do a runup.
I have a 496 in my 206 and it's internal battery must be weak or dead because if I don't fly for a while it is completely lost as far as date and location
Date Posted: 15 Apr 2022 at 4:37am
Both my units now seem to only get a GPS fix once I activate a route. Even after 10 minutes there is no GPS fix on either 540 or 440. Rebooting doesn't do anything. As soon as I hit the "activate route" button, both GPS indicators switch instantly from yellow to green. This looks like a bug to me. Anyone else have this issue, beyond the comments above?
Posted By: LarryPetro
Date Posted: 15 Apr 2022 at 9:21am
chflyer wrote:
Both my units now seem to only get a GPS fix once I activate a route. Even after 10 minutes there is no GPS fix on either 540 or 440. Rebooting doesn't do anything. As soon as I hit the "activate route" button, both GPS indicators switch instantly from yellow to green. This looks like a bug to me. Anyone else have this issue, beyond the comments above? |
My dual IFD440s have had the same behavior recently. Both units had 7+ satellites with good signals.
------------- Larry Petro - Columbia 350 @ KFME
Date Posted: 15 Apr 2022 at 9:25am
Both IFDs have been at 10.2.6.1 for approximately one year.
Date Posted: 15 Apr 2022 at 9:31am
Believe it or not, this is neither new behavior for your IFD's nor a bug. The yellow GPS nav indicator does not turn green until the respective IFD has a good GPS lock and also has an active GPS leg. The following screenshot is from the IFD540 PG with the relevant statement highlighted:
Outside of the AUX - SYS - GPS Status page, are several other indications to the IFD having a GPS lock prior to the IFD having an active GPS leg. Some of these indications include: - traffic thumbnail datablock no longer having a red X through it
- traffic information displaying on the map or traffic thumbnail
- datablock information such as GPS AGL, GS, Dist, and Rad information displayed
- Current track displayed on the MAP
- WiFi connected IFD100 shows a CHART tab (provided the IFD100 is set to use charts).
- I think even having agency identifiers for local frequencies in the active and standby com slots require the IFD to have a GPS lock, otherwise COM is displayed.
Date Posted: 15 Apr 2022 at 9:52am
Many thanks.
Funny how I never actually realized this. One statement in the manual in a section describing approach indications is a bit hidden out of plan sight though. That information should go in the main text at a more prominent location. As I almost always have a route to fly, this has never been an issue. I guess it is time to re-read the manual.
The last suggestion about com frequency station names is a very quick and readily available indication, if it really does confirm a GPS lock, since one of those frequencies is inevitably the last used before shutdown.
Date Posted: 15 Apr 2022 at 9:54am
chflyer wrote:
Many thanks.
The last suggestion about com frequency station names is a very quick and readily available indication, if it really does confirm a GPS lock, since one of those frequencies is inevitably the last used before shutdown. |
I will verify that last point the next time I go fly.
Date Posted: 15 Apr 2022 at 7:30pm
Verified - the agency identifiers for local frequencies in the active and standby com slots indicate COM until shortly after GPS lock, then the proper com agency identifier is displayed.
Date Posted: 15 Apr 2022 at 7:37pm
dmtidler wrote:
Verified - the agency identifiers for local frequencies in the active and standby com slots indicate COM until shortly after GPS lock, then the proper com agency identifier is displayed. |
Thanks for those point outs. They will be useful to check the status of the IFD before I taxi out and without the need to activate a flight plan.
