540 staying in North up
URL: http://forums.avidyne.com/forum_posts.asp?TID=691
Printed Date: 10 Jul 2025 at 11:56pm
Topic: 540 staying in North up
Posted By: billan07
Subject: 540 staying in North up
Date Posted: 01 Jun 2015 at 5:04pm
I have an intermittent problem where an IFD 540 map will display in North Up mode despite setting the display to Heading Up.  I have tried setting the display to other modes but it remains in North Up.  Often after a power cycle the unit will return to Heading Up, but on my last flight a unit remained in North Up after shutdown.  I have a dual 540 installation and both units have exhibited this behavior.  Is this a known occurrence?  If not, is there some other data I can provide to help diagnose the problem?
Date Posted: 01 Jun 2015 at 7:46pm
You may be confusing 2 issues.   If you have a heading input, you can select either heading up or track up on the Options page of the AUX tab.  It should hold this setting across power cycles.   Once on the map page, you can toggle thru the various map display choices of North Up,  Track UP (or Heading Up) Centered and Track Up (or Heading Up) Forward View.  You do this by pushing in the lower right knob to toggle thru the views.
Posted By: billan07
Date Posted: 04 Jun 2015 at 3:49pm
Ah, I understand how it works now, thanks.
